V2 fcgi transport unrecognised directive
(devel) with docker-alpine
docker
OS, relevant versions, systemd? docker? etc.
caddy/caddy:alpine
paste command here
web:
image: caddy/caddy:alpine
#image: abiosoft/caddy:1.0.3-no-stats
depends_on:
- qgisserver
- ./conf/Caddyfile:/etc/caddy/Caddyfile
- ./app:/io/www/html
ACME_AGREE: “true”
- net
d. My complete Caddyfile:
localhost:8080
root * /io/www/html
@ows {
    path_regexp map_file ^/ows/(.*)
#redir @ows /demos.html?{query}&map=/io/data/{http.regexp.map_file.1}.qgs
# localhost:8080/ows/AV_TH_V1?SERVICE=wms
# directly call QGIS via fcgi
reverse_proxy @ows qgisserver:9993{
    transport fastcgi {
        env QUERY_STRING {query}&map=/io/data/{http.regexp.map_file.1}.qgs
reloading the Caddy file I get an error saying that the transport directive is not recognised
/ $ caddy reload --config /etc/caddy/Caddyfile
2020/02/13 23:44:47.371 INFO using provided configuration {“config_file”: “/etc/caddy/Caddyfile”, “config_adapter”: “”}
reload: adapting config using caddyfile: /etc/caddy/Caddyfile:27: unrecognized directive: transport
removing the transport block makes the file reload
Oh, you just need a space here: ggisserver:9993{ so it becomes ggisserver:9993 {
No sloppy Caddyfiles :wink: The opening curly brace has to be its own token.
