v2.0.0
macOS 10.14.6
paste full file contents here
(encoding) {
encode zstd gzip
(logs) {
format json
output stderr
localhost {
import logs
import encoding
# Routes by services
import ./routes/common/customers
Is there a way to create custom log output using directives within the Caddyfile?
I would like to create logs with the following structure, removing sensitive fields (e.g., Authorization from the headers):
"time": "2020-05-14T09:31:48+00:00",
"request_method": "POST",
"request_uri": "/v1/customers",
I have tried using the API and using filtering in order to remove sensitive fields (e.g., Authorization header). For instance,
"default": {
"exclude": [
"http.log.access.log0"
"log0": {
"encoder": {
"format": "filter",
"wrap": {
"format": "json"
"fields": {
"request>headers>Authorization": {
"filter": "delete"
"include": [
"writer": {
"output": "stderr"
This removes the fields that I don’t want to appear in the logs but this doesn’t seem to be achievable using a Caddyfile. I can see from the docs that the filter format is not available through the log directive.
I’ve also tried using single_field as described by @francislavoie in a previous post but I could not get this to work as desired. For instance, specifying the following in the Caddyfile did not produce any log output at all
(logs) {
format single_field {uri}
output stderr
Can anyone suggest how to generate logs with a custom json structure including only a specific set of fields?
