Does Caddy v2 support basicauth in file_server?
I couldn’t find anything related in the v2 documentation.
Thanks!
Thanks!
Hi @HNRK,
The file server in v2 is what’s referred to as a terminating handler. The scope of its functionality is to produce a file for the client, ending the request chain.
Authentication, such as basic auth, would be a non-terminating handler (a middleware) you would introduce as part of the chain, e.g. match /path
→ basicauth foo bar
→ serve file.
Doesn’t look like basic auth is in yet, though.
Ahh okay, thank you for the explanation!
Okay, then I can safely open an issue/feature request for it.
EDIT: Created PR for v2 basicauth: v2: basicauth feature · Issue #2747 · caddyserver/caddy · GitHub
Implemented in http: authentication module; hash-password cmd; http_basic provider · caddyserver/caddy@f8366c2 · GitHub.
