1. My Caddy version (caddy version
v2.0.0 h1:pQSaIJGFluFvu8KDGDODV8u4/QRED/OPyIR+MWYYse8
Ubuntu 16.04.6 LTS, systemd
via systemd
After=network.target
email webmaster@***.***
(headers) {
-Server
X-Robots-Tag "none"
Referrer-Policy "same-origin"
X-Frame-Options "SAMEORIGIN"
X-Xss-Protection "1; mode=block"
https://a***.b***.c** {
root * /var/www/html
import headers
basicauth {
user_1 hashed_pwd_1
basicauth /projectA/* {
user_1 hashed_pwd_1
user_2 hashed_pwd_2
basicauth /projectB/* {
user_1 hashed_pwd_1
user_3 hashed_pwd_3
respond /conf/* 403 {
close
respond /projectA/goodies/* 403 {
close
file_server {
index index.html index.php
php_fastcgi unix//run/php/php7.0-fpm.sock
I am having issues with what seems to the the precedence of multiple basicauth directives. I have a file server with a root directory, and two subdirectories - /projectA and /projectB. I would like to have a master user/pwd combination that protects the entire site (root directory down), and then create separate user/pwd combinations which will grant access to each subdirectory. With the current configuration, the user_2 and user_3 credentials don’t work. The user_1 credentials work as they should.
The user_2 and user_3 login credentials don’t grant access
Changing the order of the 3 basicauth directives had no effect, nor did wrapping them in a route block to try and force a certain order. When I comment out the first (global) basicauth directive, the user_2 and user_3 credentials work in the subdirectories as they should, but now the root directory is unprotected.
