Caddy v1.0.3
Inside of a Docker container (abiosoft)
Docker
docker run caddy
image: abiosoft/caddy:no-stats
restart: always
- $HOME/data/backend/static:/static
- $HOME/data/caddy/Caddyfile:/etc/Caddyfile
- $HOME/data/caddy/.caddy:/root/.caddy
- 443:443
- net
www.domain.com, domain.com {
# Remove trailing slashes
rewrite {
if {path} ends_with /
r ^/(.*)/$
to /{1}
redir 301 {
if {path} not /
/ {rewrite_uri}
# Redirect the old users to the new admin
redir /users https://admin.domain.com
# Special mappings
redir 301 {
# REDACTED: Simple redirect for some special paths
proxy / client:80 {
gzip
3. The problem Iām having:
I am trying to take old URLs still saved in search engines from the old system, and redirect them to the new structure. The idea is to take URLs such as
domain.com/obj/print.php?obj_id=XXXX
and redirect them to:
domain.com/XXXX
Not relevant
I cannot find how to capture the id (a 4 digit number) and reuse it to redirect the user to the new page, while also returning a 301.
