Using Wildcard certificate for multihosts*.thedomain.tld subdomains while having other subdomains
I want to add a wildcard for a specific hostname like multihosts*.thedomain.tld
for this I need to use the wildcard cert.
for everyhtign else I want to still use specific certs as I currently do.
so my config works if I remove:
multihosts*.thedomain.tld - part.
I need to use around 300 multihosts.thedomain.tld
so I really want to use wildcard there…
I have the following config:
# DNS API - SSL
    acme_dns cloudflare MYTOKEN..
# Hosts
multihosts*.thedomain.tld{
    reverse_proxy https://10.255.252.3:7443 {
            tls_insecure_skip_verify
anothersubdomain.thedomain.tld{
    reverse_proxy https://10.255.255.7:443 {
asubdomainialsouse.thedomain.tld {
    reverse_proxy https://10.255.255.6:443 {
Error: adapting config using caddyfile: subject does not qualify for certificate: multihosts*.thedomain.tld'
v2.6.4 built with acme_dns cloudflare module using xcaddy
I don’t understand what you mean by multihosts*. That doesn’t make sense.
Wildcards must have a single * as the left-most label.
Please completely fill out the help topic template as per the forum rules. Don’t omit any sections.
