1. Output of caddy version
v2.6.2
Ubuntu 20.04.5 LTS
caddy add-package github.com/darkweak/souin/plugins/caddy github.com/caddyserver/transform-encode
Default unchanged.
Not relevant to question.
I installed the stable release from cloudsmith as in Install — Caddy Documentation.
Then I added to packages which worked great.
In order to avoid the next caddy release removing the created binary with the two packages I found out there are already solutions to this:
My questions:
Do you think it would be ok to take the caddy binary that was created by add-package, put it in a special directory where update-alternatives
then will symlink it, this way pretending it is my “custom binary”?
This will simply take care of avoiding caddy updates from the repo replacing the ones with the extra modules. A caddy upgrade
might possibly re-build the latest caddy with the latest modules “in-place” on the default location which is also ok for me here.
If possible I want to avoid a local build system and some Ansible steps.
Not necessary.
Installing caddy like recommended via cloudsmith, adding packages.
