Using two local domains shows single project app in both!
I cannot access 2nd app in the second local domain!
No error!
v2.10.2
I used brew
OSX
caddy run --config ./Caddyfile
firstapp.local {
	# Serve your build folder
	root * ./dist
	# Enable compression (already working)
	encode gzip zstd
	# Use self-signed certificate for local HTTPS
	tls internal
	# 🚀 CACHE RULES
	# Cache static assets for 1 year
	@static {
		path *.ico *.css *.js *.gif *.jpg *.jpeg *.png *.webp *.svg *.woff *.woff2 *.ttf
	header @static Cache-Control "public, max-age=31536000, immutable"
	# Don't cache HTML
	@html {
		path *.html
	header @html Cache-Control "no-cache"
	# Optional: Security headers
		X-Frame-Options "DENY"
secondapp.local {
	reverse_proxy http://localhost:4321
	root * ./dist
	encode gzip zstd
	tls internal
	# 🚀 CACHE RULES
	@static {
	# Don't cache HTML
	@html {
		path *.html
FYI: first app is static website and second app is SSR
Take a look at the directive order. It never gets to the reverse_proxy part at all. Also, why your second app has the same configuration as you first app + reverse_proxy? It doesn’t make sense.
No need to use file_server with reverse_proxy.
