I’m trying to use expression matching to deny access to certain sub directories. The expression matching work as expected, however I’d like to add the variable http.request.host to a path but this value needs concatenating to make the complete path.
The hardcoded version is shown here:
@block {
expression `path("/client/*") && ! path("/client/THESITE.COM/*")`
respond @block 404
I’d like the replace the parts in CAPS above using the following pseudo code:
@block {
expression `path("/client/*") && ! path("/client/{http.request.host}/*")`
respond @block 404
So that with multiple sites I don’t have to edit this value manually.
I can’t seem to find any documentation about how to achieve this. The variable http.request.host is correct, but I’m not sure about the syntax for the 2nd path
Not really relevant as I don’t know the syntax
V2.6.4
Installed on Linux via apt install caddy running under systemd
Ubuntu 22.04
# domain name.
http_port 80
https_port 443
# Pull out to make each site as simple as possbile
(websockets) {
@websockets {
header Connection Upgrade
header Upgrade websocket
eyeronic.duckdns.org:443 {
root * /mnt/c/source/eyeronic_iss/trunk/www
import websockets
route /socket {
reverse_proxy @websockets 127.0.0.1:8089
@block {
expression `path("/client/*") && ! path("/{{http.request.host}}/*")`
respond @block {http.request.host}
tls internal
php_fastcgi unix//var/run/php/php8.1-fpm.sock
This might be relevant but not sure:
