Hi folks,
I am totally new to this rocket chat thing.
What have I done?
Installed Ubuntu Server (22.04LTS) as virtual machine inside of a domain.
What is actually working:
I can access rocket chat over IP (http://nnn.nnn.nnn.nnn:3000
I can access rocket chat over domain (http://chat.url.com:3000
I have seen caddy and my thought was: Create idea!
I followed this “guide”:
But nothing works.
I am confused.
I have seen a lot of “tutorials” where was written: “The caddyfile should look like this or this”. In my case…These files where totally blank.
The one which you can access via nano caddyfile in the home directory and the one, which is in /var/snap/rocketchat-server/current.
Is this normal?
Now my questions:
Where can I configure that rocket chat works with the URL chat.url.com
instead of chat.url.com:3000
Which caddyfile of the two has to be configured?
What is the configuration?
Actually I have written there:
https://chat.url.com
tls self_signed
localhost:3000 {
websocket
Where can I implement my own SSL certificate? I have a wildcard certificate for the domain.
And one more thing…
none of the commands find here down below are working on my machine. It always says “command not found”.
Maybe the caddy server itself is installed wrong? Should I install it from scratch?
Many thanks in advance!
