Using / setting ACME profiles as of 2.10
Is there currently a way to set an ACME profile as default whenever a given issuer is used, or does it need to be manually configured per site block using the ACME settings (which as I understand it would also disable falling over to ZeroSSL?):
example.com {
          acme https://acme-v02.api.letsencrypt.org/directory {
                  profile tlsserver
Ideally I could configure all of my sites to use tlsserver when getting a certificate from LE, without impacting being able to fail over to ZeroSSL if necessary.
I realize that I’ve snipped out some of the help questions here, but I think this is more of a discussion, rather than a specific issue I’m facing.
N/A, configuration question, not a specific error/log related question
CentOS Stream 10
You can use the cert_issuer global option, with the same syntax (starting with the acme token):
Perfect, thanks!
