Using 'remote_host' in layer4
I’d like to use the ‘http.matchers.remote_host’ module within the ‘layer4’ module, but I’m unsure on how to.
The current Caddyfile I have works, but instead of relying on IP addresses, I’d like to use hostnames instead. I’m using docker containers, so it should be possible to resolve the container’s name to its IP address.
On the layer4 module’s README, it says:
“layer4.matchers.http - matches connections that start with HTTP requests. In addition, any http.matchers modules can be used for matching on HTTP-specific properties of requests, such as header or path. Note that only the first request of each connection can be used for matching.”
I’m aware it’s for HTTP, but is it possible to have something like “layer4.matchers.http.matchers.remote_host” so I could resolve a hostname? If so, could someone give an example doing so with my Caddyfile? If not, is there an alternative?
Also, I’d like to know how to log the ‘remote_ip’ and ‘server_name’ fields for all connections.
N/A
v2.9.0-beta.3 h1:tlqfbJMRNY6vnWwaQrnWrgS+wkDXr9GIFUD/P+HY9vA=
I built a caddy image with this Dockerfile:
FROM caddy:2.9-builder-alpine AS builder
RUN xcaddy build \
    --with github.com/mholt/caddy-l4 \
    --with github.com/muety/caddy-remote-host
FROM caddy:2.9-alpine
Docker compose 1.29.2-3 in a rootless Debian LXC on Proxmox 8.3.0.
docker compose up -d
    image: caddy-layer4:2.9-alpine
    cap_add:
      - NET_ADMIN
      - ./caddy/caddy/:/etc/caddy/
      - ./caddy/site:/srv
      - ./caddy/data:/data
      - ./caddy/config/:/config
    layer4 {
        :443 {
            @google tls sni google.com
            route @google {
                subroute {
                    @allowed remote_ip 172.16.0.5
                    route @allowed {
                        proxy google.com:443
Best if you open an issue on the caddy-l4 repo.
