Using maxmind_geolocation with reverse_proxy
I’m trying to set up caddy so that accesses coming from Portugal get reverse-proxied through, and anything from anywhere else gets a 403 error. Unfortunately, I can’t seem to figure out how to get the config file for it right.
v2.6.4 with the porech/caddy-maxmind-geolocation module.
Downloaded the binary from Download Caddy
Ubuntu Linux Jammy, amd64.
./caddy_geolock start
	acme_ca https://api.buypass.com/acme/directory
	email pedro.mcs@gmail.com
	key_type p256
syaoran.puto.pt {
	file_server browse
ircproxy.puto.pt {
	reverse_proxy * 127.0.0.1:9500
projetos.puto.pt {
	@mygeofilter {
		maxmind_geolocation {
			db_path "/home/ubuntu/GeoLite2-Country.mmdb"
			allow_countries PT
	reverse_proxy * 127.0.0.1:5000 {
		@mygeofilter
	basicauth /bridge/* {
		[USERNAME] [PASSWORD GOES HERE]
I’m basically trying to get the @mygeofilter and reverse_proxy sections to work together, but it doesn’t seem to be working – the current attempt just lets anybody through.
That’s because:
The * means “every request”. So you’re allowing every request through the filter. And @mygeofilter inside the block shouldn’t even parse correctly, I’m surprised you don’t get errors.
Do this instead:
reverse_proxy @mygeofilter 127.0.0.1:5000
Technically that syntax used to define a response matcher. But I’m surprised passing no arguments to it doesn’t error, yeah. I’ll look into that.
What you probably want though is to reject the request if the not from PT, so you should do this instead:
@mygeofilter not maxmind_geolocation {
	allow_countries PT
error @mygeofilter 403
reverse_proxy 127.0.0.1:5000
Ah good point, forgot about that!
