Trying to run the git instaweb command does not seem to recognize an httpd daemon.
git instaweb --start --httpd caddy
caddy not found. Install caddy or use --httpd to specify another httpd daemon.
systemctl status caddy
● caddy.service - Caddy
Loaded: loaded (/etc/systemd/system/caddy.service; enabled; preset: enabled)
Drop-In: /nix/store/4haw5096s0f4snq490yv4nsw2d56b1vi-system-units/caddy.service.d
└─overrides.conf
Active: active (running) since Mon 2024-08-05 08:29:18 PDT; 2h 19min ago
Main PID: 1774 (caddy)
IP: 4.5K in, 5.3K out
IO: 40.2M read, 76.0K written
Tasks: 18 (limit: 37544)
Memory: 51.4M (peak: 56.9M)
CPU: 233ms
└─1774 /nix/store/c496kw0yni8wjg8636dwvnjb4hcn21c7-caddy-2.7.6/bin/caddy run --config /etc/caddy/caddy_config --adapter caddyfile
NixOS 24.05, x86, systemd
Systemd service is used to run Caddy. The command to run Caddy is:
systemctl cat caddy.service
# /etc/systemd/system/caddy.service
# caddy.service
# for your installation.
Type=notify
ExecStart=/nix/store/c496kw0yni8wjg8636dwvnjb4hcn21c7-caddy-2.7.6/bin/caddy run --environ --config /etc/caddy/Caddyfile
ExecReload=/nix/store/c496kw0yni8wjg8636dwvnjb4hcn21c7-caddy-2.7.6/bin/caddy reload --config /etc/caddy/Caddyfile --force
# /nix/store/4haw5096s0f4snq490yv4nsw2d56b1vi-system-units/caddy.service.d/overrides.conf
StartLimitBurst=10
StartLimitIntervalSec=14400
X-Reload-Triggers=/nix/store/caf22kfmxl10mr8wwxv2sh2sjpn35517-X-Reload-Triggers-caddy
Environment="LOCALE_ARCHIVE=/nix/store/naa6s54b4hc55740lblbs9phv7xk317h-glibc-locales-2.39-52/lib/locale/locale-archive"
Environment="PATH=/nix/store/php4qidg2bxzmm79vpri025bqi0fa889-coreutils-9.5/bin:/nix/store/jjcsr5gs4qanf7ln5c6wgcq4sn75a978-findutils-4.9.0/bin:/nix/store/28gpmx3z6ss3znd7fhmrzmvk3x5lnfbk-gnugrep-3.11/bin:/nix/store/5zjms21vpxlkbc0qyl>
Environment="TZDIR=/nix/store/y6hmqbmbwq0rmx1fzix5c5jszla2pzmp-tzdata-2024a/share/zoneinfo"
ExecReload=
ExecReload=/nix/store/c496kw0yni8wjg8636dwvnjb4hcn21c7-caddy-2.7.6/bin/caddy reload --config /etc/caddy/caddy_config --adapter caddyfile --force
ExecStart=
ExecStart=/nix/store/c496kw0yni8wjg8636dwvnjb4hcn21c7-caddy-2.7.6/bin/caddy run --config /etc/caddy/caddy_config --adapter caddyfile
LogsDirectory=caddy
NoNewPrivileges=true
PrivateDevices=true
ProtectHome=true
ReadWritePaths=/var/lib/caddy
Restart=on-failure
RestartPreventExitStatus=1
RestartSec=5s
StateDirectory=caddy
...skipping...
# caddy.service
Type=notify
StartLimitBurst=10
ExecReload=
ExecStart=
LogsDirectory=caddy
PrivateDevices=true
ProtectHome=true
Restart=on-failure
RestartSec=5s
cat /etc/caddy/caddy_config
level ERROR
https://devpress.localhost:443 {
output file /var/log/caddy/access-https://devpress.localhost:443.log
root * /mnt/www/devpress
php_fastcgi unix//run/phpfpm/devpress.localhost.sock
https://nerdpress.localhost:443 {
output file /var/log/caddy/access-https://nerdpress.localhost:443.log
root * /mnt/www/nerdpress
php_fastcgi unix//run/phpfpm/nerdpress.localhost.sock
