v2.5.1 h1:bAWwslD1jNeCzDa+jDCNwb8M3UJ2tPa8UZFFzPVmGKs=
Arch Linux
Linux 5.18.7-arch1-1 #1 SMP PREEMPT_DYNAMIC Sat, 25 Jun 2022 20:22:01 +0000 x86_64 GNU/Linux
PHP 8.1.7 fpm
cd /srv/authtest ; ./caddy run
N/A
http_port 1081 # Doesn't matter, we're not using it here.
# The site that I want to authenticate for.
localhost:8080 {
forward_auth 127.0.0.1:8081 {
uri /auth.php
root * def
# My authentication service, that should only be accessible from
# the local host.
http://127.0.0.1:8081 {
bind 127.0.0.1
root * auth
php_fastcgi unix//var/run/php-fpm/php-fpm.sock
# vim: ts=8 sw=8 noexpandtab
I’m looking to write my own authenticator in PHP, leveraging the new forward_auth directive.
To begin with, the auth.php file is just:
<?php
http_response_code(401);
echo "<h1>Auth site</h1>";
So when I access https://localhost:8080/ I expect a 401 response with the one line <h1>Auth site</h1> in the body. Instead I get a 200 response and no body.
Am I missing something with how forward_auth is suppose to work?
All files (sans Caddy executable) (1351 bytes): authtest.zip
See logs below.
Output from curl -v https://localhost:8080/ is:
* Trying 127.0.0.1:8080...
* Connected to localhost (127.0.0.1) port 8080 (#0)
* ALPN: offers h2
* ALPN: offers http/1.1
* CApath: none
* ALPN: server accepted h2
* subject: [NONE]
* start date: Jun 27 05:38:36 2022 GMT
* expire date: Jun 27 17:38:36 2022 GMT
* subjectAltName: host "localhost" matched cert's "localhost"
* issuer: CN=Caddy Local Authority - ECC Intermediate
* SSL certificate verify ok.
* h2h3 [:method: GET]
* h2h3 [:path: /]
* h2h3 [:scheme: https]
* h2h3 [:authority: localhost:8080]
* h2h3 [user-agent: curl/7.83.1]
* h2h3 [accept: */*]
* Using Stream ID: 1 (easy handle 0x562e32f17fa0)
> GET / HTTP/2
> Host: localhost:8080
> accept: */*
< HTTP/2 200
< date: Mon, 27 Jun 2022 06:36:23 GMT
< server: Caddy
< server: Caddy
< server: Caddy
< content-length: 0
Corresponding caddy service log output is:
2022/06/27 06:35:41.206 INFO using adjacent Caddyfile
2022/06/27 06:35:41.208 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2022/06/27 06:35:41.208 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv1"}
2022/06/27 06:35:41.208 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc00040e930"}
2022/06/27 06:35:41.209 DEBUG http starting server loop {"address": "[::]:1081", "http3": false, "tls": false}
2022/06/27 06:35:41.209 DEBUG http starting server loop {"address": "127.0.0.1:8081", "http3": false, "tls": false}
2022/06/27 06:35:41.209 DEBUG http starting server loop {"address": "[::]:8080", "http3": false, "tls": true}
2022/06/27 06:35:41.209 INFO http enabling automatic TLS certificate management {"domains": ["localhost"]}
2022/06/27 06:35:41.210 WARN tls stapling OCSP {"error": "no OCSP stapling for [localhost]: no OCSP server specified in certificate", "identifiers": ["localhost"]}
2022/06/27 06:35:41.210 DEBUG tls.cache added certificate to cache {"subjects": ["localhost"], "expiration": "2022/06/27 17:38:36.000", "managed": true, "issuer_key": "local", "hash": "21f5de718760485841efeb9e35a21d367ba5ed086427e58c81f77756fb5b5a39", "cache_size": 1, "cache_capacity": 10000}
2022/06/27 06:35:41.210 INFO tls cleaning storage unit {"description": "FileStorage:/home/evmcl/.local/share/caddy"}
2022/06/27 06:35:41.210 INFO tls finished cleaning storage units
2022/06/27 06:35:41.228 INFO pki.ca.local root certificate is already trusted by system {"path": "storage:pki/authorities/local/root.crt"}
2022/06/27 06:35:41.230 INFO autosaved config (load with --resume flag) {"file": "/home/evmcl/.config/caddy/autosave.json"}
2022/06/27 06:35:41.230 INFO serving initial configuration
2022/06/27 06:36:23.827 DEBUG tls.handshake choosing certificate {"identifier": "localhost", "num_choices": 1}
2022/06/27 06:36:23.827 DEBUG tls.handshake default certificate selection results {"identifier": "localhost", "subjects": ["localhost"], "managed": true, "issuer_key": "local", "hash": "21f5de718760485841efeb9e35a21d367ba5ed086427e58c81f77756fb5b5a39"}
2022/06/27 06:36:23.827 DEBUG tls.handshake matched certificate in cache {"subjects": ["localhost"], "managed": true, "expiration": "2022/06/27 17:38:36.000", "hash": "21f5de718760485841efeb9e35a21d367ba5ed086427e58c81f77756fb5b5a39"}
2022/06/27 06:36:23.829 DEBUG http.handlers.reverse_proxy selected upstream {"dial": "127.0.0.1:8081", "total_upstreams": 1}
2022/06/27 06:36:23.829 DEBUG http.handlers.reverse_proxy upstream roundtrip {"upstream": "127.0.0.1:8081", "duration": 0.000334876, "request": {"remote_ip": "127.0.0.1", "remote_port": "33440", "proto": "HTTP/2.0", "method": "GET", "host": "localhost:8080", "uri": "/auth.php", "headers": {"Accept": ["*/*"], "X-Forwarded-For": ["127.0.0.1"], "X-Forwarded-Proto": ["https"], "X-Forwarded-Host": ["localhost:8080"], "X-Forwarded-Method": ["GET"], "X-Forwarded-Uri": ["/"], "User-Agent": ["curl/7.83.1"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "localhost"}}, "headers": {"Content-Length": ["0"], "Server": ["Caddy"], "Date": ["Mon, 27 Jun 2022 06:36:23 GMT"]}, "status": 200}
2022/06/27 06:36:23.829 DEBUG http.handlers.reverse_proxy handling response {"handler": 1}
I have confirmed that my auth.php end-point works with curl -v http://127.0.0.1:8081/auth.php:
* Trying 127.0.0.1:8081...
* Connected to 127.0.0.1 (127.0.0.1) port 8081 (#0)
> GET /auth.php HTTP/1.1
> Host: 127.0.0.1:8081
> User-Agent: curl/7.83.1
< HTTP/1.1 401 Unauthorized
< Content-Type: text/html; charset=UTF-8
< Server: Caddy
< Status: 401 Unauthorized
< X-Powered-By: PHP/8.1.7
< Date: Mon, 27 Jun 2022 06:38:33 GMT
< Content-Length: 18
* Connection #0 to host 127.0.0.1 left intact
<h1>Auth site</h1>
And if I comment out the forward_auth directive, I do get back the simple one-line contents of the index.html file in the def site. curl -v https://localhost:8080/ with no forward_auth:
* ALPN: offers h2
* CApath: none
* subject: [NONE]
* h2h3 [:path: /]
* Using Stream ID: 1 (easy handle 0x5558902c1fa0)
> GET / HTTP/2
> accept: */*
< HTTP/2 200
< accept-ranges: bytes
< etag: "re4huwm"
< last-modified: Mon, 27 Jun 2022 06:25:44 GMT
< server: Caddy
< content-length: 22
< date: Mon, 27 Jun 2022 06:41:13 GMT
<h1>Default site</h1>
