I’m trying to setup DynamicDNS via Caddy using the mholt/caddy-dynamicdns and caddy-dns/cloudflare, as I have registered a domain via Cloudflare. I don’t believe it’s functioning correctly as sudo systemctl status caddy returns authentication errors I believe are coming from Cloudflare (based on comments I’ve found in other help topics), and I’ve tried setting the IPs on Cloudflare to different IPs to test if it was working anyway, it didn’t appear to be after restarting Caddy.
Full output from system boot onwards:
-- Boot cf9746c6657e418b88ba21658622f45d --
Oct 04 09:46:37 jelly-pc systemd[1]: Starting caddy.service - Caddy...
Oct 04 09:46:37 jelly-pc caddy[3072]: caddy.HomeDir=/var/lib/caddy
Oct 04 09:46:37 jelly-pc caddy[3072]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Oct 04 09:46:37 jelly-pc caddy[3072]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Oct 04 09:46:37 jelly-pc caddy[3072]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Oct 04 09:46:37 jelly-pc caddy[3072]: caddy.Version=v2.8.4 h1:q3pe0wpBj1OcHFZ3n/1nl4V4bxBrYoSoab7rL9BMYNk=
Oct 04 09:46:37 jelly-pc caddy[3072]: runtime.GOOS=linux
Oct 04 09:46:37 jelly-pc caddy[3072]: runtime.GOARCH=amd64
Oct 04 09:46:37 jelly-pc caddy[3072]: runtime.Compiler=gc
Oct 04 09:46:37 jelly-pc caddy[3072]: runtime.NumCPU=12
Oct 04 09:46:37 jelly-pc caddy[3072]: runtime.GOMAXPROCS=12
Oct 04 09:46:37 jelly-pc caddy[3072]: runtime.Version=go1.22.2
Oct 04 09:46:37 jelly-pc caddy[3072]: os.Getwd=/
Oct 04 09:46:37 jelly-pc caddy[3072]: LANG=en_US.UTF-8
Oct 04 09:46:37 jelly-pc caddy[3072]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/snap/bin
Oct 04 09:46:37 jelly-pc caddy[3072]: NOTIFY_SOCKET=/run/systemd/notify
Oct 04 09:46:37 jelly-pc caddy[3072]: USER=caddy
Oct 04 09:46:37 jelly-pc caddy[3072]: LOGNAME=caddy
Oct 04 09:46:37 jelly-pc caddy[3072]: HOME=/var/lib/caddy
Oct 04 09:46:37 jelly-pc caddy[3072]: INVOCATION_ID=eb9282e79dc44525ac894c60d071c423
Oct 04 09:46:37 jelly-pc caddy[3072]: JOURNAL_STREAM=8:13210
Oct 04 09:46:37 jelly-pc caddy[3072]: SYSTEMD_EXEC_PID=3072
Oct 04 09:46:37 jelly-pc caddy[3072]: MEMORY_PRESSURE_WATCH=/sys/fs/cgroup/system.slice/caddy.service/memory.pressure
Oct 04 09:46:37 jelly-pc caddy[3072]: MEMORY_PRESSURE_WRITE=c29tZSAyMDAwMDAgMjAwMDAwMAA=
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.468926,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.473716,"msg":"adapted config to JSON","adapter":"caddyfile"}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.4756858,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.476056,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.4760644,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.4770815,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0006dd180"}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.4795215,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.4795687,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 7168 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.481027,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.481067,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.4810722,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["t4ngo.xyz"]}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.496578,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/var/lib/caddy/.local/share/caddy","instance":"7ea5fa63-f812-450f-bc54-78ec68e8b0b1","try_again":1728121597.4965768,"try_again_in":86399.999999702}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.496642,"logger":"tls","msg":"finished cleaning storage units"}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.4974716,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.4975026,"msg":"serving initial configuration"}
Oct 04 09:46:37 jelly-pc systemd[1]: Started caddy.service - Caddy.
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"error","ts":1728035197.881608,"logger":"dynamic_dns","msg":"unable to lookup current IPs from DNS records","error":"got error status: HTTP 400: [{Code:6003 Message:Invalid request headers ErrorChain:[{Code:6111 Message:Invalid format for Authorization header}]}]"}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.933121,"logger":"dynamic_dns","msg":"updating DNS record","zone":"t4ngo.xyz","type":"A","name":"@","value":"116.255.4.93","ttl":0}
Oct 04 09:46:37 jelly-pc caddy[3072]: {"level":"info","ts":1728035197.9331403,"logger":"dynamic_dns","msg":"updating DNS record","zone":"t4ngo.xyz","type":"A","name":"www","value":"116.255.4.93","ttl":0}
Oct 04 09:46:38 jelly-pc caddy[3072]: {"level":"error","ts":1728035198.1498227,"logger":"dynamic_dns","msg":"failed setting DNS record(s) with new IP address(es)","zone":"t4ngo.xyz","error":"got error status: HTTP 400: [{Code:6003 Message:Invalid request headers ErrorChain:[{Code:6111 Message:Invalid format for Authorization header}]}]"}
Oct 04 09:46:38 jelly-pc caddy[3072]: {"level":"info","ts":1728035198.1498814,"logger":"dynamic_dns","msg":"finished updating DNS","current_ips":["116.255.4.93"]}
The two problematic lines (extracted from the log above):
Running on an Ubuntu 24.04.1 LTS (GNU/Linux 6.8.0-45-generic x86_64).
Caddy is not running in Docker.
I’m using Caddyfile, which is stored in /etc/caddy/Caddyfile.
Added the two plugins to Caddy with xcaddy, and then replaced the old Caddy with:
sudo xcaddy build --with github.com/caddy-dns/cloudflare --with github.com/mholt/caddy-dynamicdns
mv caddy /usr/bin/caddy
I run Caddy via systemctl, using the following commands:
sudo systemctl start caddy
sudo systemctl restart caddy
sudo systemctl stop caddy
I’ve only really been using restart and status.
My Caddyfile also contains reverse_proxy settings for my jellyfin and transmission instances (which are running in docker), the full file is:
# Global Options
dynamic_dns {
provider cloudflare {env.CF_API_TOKEN}
domains {
t4ngo.xyz @ www
versions ipv4
# Cloudflare Domain
t4ngo.xyz {
# Jellyfin configuration
redir /jellyfin /jellyfin/
reverse_proxy /jellyfin/* 127.0.0.1:8096
# Transmission configuration
redir /transmission /transmission/
reverse_proxy /transmission/* 127.0.0.1:9091
6. Other relevant information:
Also worth noting that my ~/.bashrc has my API token at the bottom: export CF_API_TOKEN="IHAVEREPLACEDTHETOKENWITHTHISTEXT", the token is 40 characters worth of numbers, letters, and a few symbols.
On Cloudflare, I have two DNS records for t4ngo.xyz. They’re both A type .One name is set to t4ngo.xyz, the other is www. Proxy status is ‘DNS only’ for both. TTL is set to auto for both.
My API token permissions are Zone.Zone, Zone.DNS, resources set to All zones. I have tried remaking this token with several different configurations, but none seem to be working.
Also, I’m relatively new to running a machine like this, although I do have some experience with Ubuntu, running Docker, Jellyfin, and Caddy are all new to me. If I’ve left anything out, please let me know. Thanks heaps for any help.
