Using docker Caddy is not generating log per site
CADDY_VERSION v2.2.1
running in docker
linux x86_64 Ubuntu 20.04.1 LTS
Docker 5.20
avec portainer agent
Standard portainer config import
volume
caddy_config	/config
caddy_data	/data
/etc/caddy/Caddyfile	/etc/caddy/Caddyfile
env
TZ	Europe/Paris
#Caddyfile
    #debug
    #auto_https disable_redirects
    #auto_https off
    #http_port 80
    #https_port 443
www.theg.vg {
    reverse_proxy 192.168.10.200
        output file /var/log/caddy/www_access.log {
            roll_size 100mb
            roll_keep 5
            roll_keep_for 720h
b.theg.vg {
# Description : komga-bd
    reverse_proxy 192.168.10.242:8080
        output file /var/log/caddy/komga-bd_access.log {
            roll_size 100mb
            roll_keep 5
            roll_keep_for 720h
j.theg.vg {
# Description : komga-jdr
    reverse_proxy 192.168.10.242:8100
        output file /var/log/caddy/komga-jdr_access.log {
            roll_size 100mb
            roll_keep 5
            roll_keep_for 720h
p.theg.vg {
# Description : komga-presse
    reverse_proxy 192.168.10.242:8090
        output file /var/log/caddy/komga-presse_access.log {
            roll_size 100mb
            roll_keep 5
            roll_keep_for 720h
no log are generated in the folder /var/log/caddy/
no error message
{"level":"info","ts":1608059831.6418629,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"},
{"level":"info","ts":1608059831.6499827,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]},
{"level":"info","ts":1608059831.6541324,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443},
{"level":"info","ts":1608059831.6542213,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"},
{"level":"info","ts":1608059831.654762,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["b.theg.vg","j.theg.vg","p.theg.vg","www.theg.vg"]},
{"level":"info","ts":1608059831.6541402,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000320850"},
{"level":"info","ts":1608059831.6630588,"logger":"tls","msg":"cleaned up storage units"},
{"level":"info","ts":1608059831.6635895,"msg":"autosaved config","file":"/config/caddy/autosave.json"},
{"level":"info","ts":1608059831.6636217,"msg":"serving initial configuration"},
set everyon RW on caddy log folder
user@kleber:/etc/caddy$ ls -la /var/log/ | grep caddy
drwxrwxrwx 2 root root 4096 Dec 15 19:08 caddy
it is the same Caddyfile used in another machine for test purpose where caddy is running in standard apt install, and logs are generated
I’m confused. If you’re running in Docker, then Caddy should be running as root inside the container, so it should have no trouble writing basically anywhere inside the container.
Are you looking for the logs inside the container or on the host? There seems to be a disconnect there.
You said your volumes are these:
caddy_data	/data
None of those involve /var/log/caddy, so the logs would never appear on the host.
@francislavoie, and… you are perfectly right. i’m myself confuse and did not set the path in the docker config.
so focused in the caddyfile config, i forgot that :sweat_smile: :tired_face:
Many thanks
and sorry for the noise
:slight_smile:
