Hi there!
2.3.0
Docker version 20.10.2 on Debian 10.8.
docker rmi -f caddy > /dev/null
docker build -t caddy:latest .
docker run -d \
--log-opt max-size=10m \
--log-opt max-file=5 \
--memory="3g" \
--name=acme-caddy \
--restart=unless-stopped \
-e ACME_CADDY_DATABASE_DB=$ACME_CADDY_DATABASE_DB \
-e ACME_CADDY_DATABASE_HOST=$ACME_CADDY_DATABASE_HOST \
-e ACME_CADDY_DATABASE_PASSWORD=$ACME_CADDY_DATABASE_PASSWORD \
-e ACME_CADDY_DATABASE_PORT=$ACME_CADDY_DATABASE_PORT \
-e ACME_CADDY_DATABASE_USERNAME=$ACME_CADDY_DATABASE_USERNAME \
-p 80:80 \
-p 443:443 \
-v $PWD/Caddyfile:/etc/caddy/Caddyfile \
caddy:latest
Here is the Dockerfile:
FROM caddy:2.3.0-builder AS builder
RUN xcaddy build \
--with github.com/gamalan/caddy-tlsredis
FROM caddy:2.3.0
email "support@acme.com"
on_demand_tls {
ask "https://service.acme.com/newspages"
burst 60
interval 1m
storage redis {
host "{$ACME_CADDY_DATABASE_HOST}"
port "{$ACME_CADDY_DATABASE_PORT}"
username "{$ACME_CADDY_DATABASE_USERNAME}"
password "{$ACME_CADDY_DATABASE_PASSWORD}"
db {$ACME_CADDY_DATABASE_DB}
key_prefix "caddy"
value_prefix "caddy-storage"
timeout 10
tls_enabled "false"
tls_insecure "true"
*.staging.acme.news {
encode zstd gzip
reverse_proxy https://acme-newspage-ovj16u24ja-uc.a.run.app {
fail_duration 55s
header_up host {http.reverse_proxy.upstream.hostport}
header_up +acme-domain {http.request.host}
header_down -server
on_demand
:443 {
encode zstd gzip
reverse_proxy https://acme-newspage-vasm4c6eca-uc.a.run.app {
fail_duration 55s
header_down -server
on_demand
As you can see in the Caddyfile, I have 2 site definitions, one for *.staging.acme.news
and a fallback :443
If I open https://test.acme.news, then the definition for :443
is used and everything works. However, if I open https://test.staging.acme.news, then the site configuration that is used is still :443
whereas I was expecting *.staging.acme.news
to be picked.
What I would like is to use a different reverse_proxy URL based on whether Caddy receives a request from *.staging.acme.news
or *.acme.news
No error message. The problem is about site definition.
I tried changing the order of the definitions and replacing :443
by *.acme.news:443
but in this last case, even https://test.acme.news is no longer working.
Does :443
have priority over all definitions whatever its place is in the Caddyfile?
