Using Cloudflare certificates with a policy
v2.4.6
caddy run --config /etc/caddy/config.json
Running caddy from docker image in Alpine Linux v3.14
K8s deployment using helm charts
apiVersion: apps/v1
kind: Deployment
metadata:
  namespace: default
  labels:
    app.kubernetes.io/instance: caddy-controller
    app.kubernetes.io/managed-by: Helm
    app.kubernetes.io/name: caddy
    app.kubernetes.io/version: 1.16.0
    helm.sh/chart: caddy-0.1.0
  annotations:
    deployment.kubernetes.io/revision: '38'
    meta.helm.sh/release-name: caddy-controller
    meta.helm.sh/release-namespace: default
spec:
  replicas: 2
  selector:
    matchLabels:
  template:
    metadata:
      namespace: default
      creationTimestamp: null
      labels:
    spec:
        - name: caddy-startup-script
          configMap:
            items:
              - key: SCRIPT
                path: script.sh
            defaultMode: 504
      containers:
        - name: caddy
          image: registry.gitlab.com/komibi/cms/caddy:2-redis
          command:
            - /application/scripts/script.sh
            - name: http
              containerPort: 80
              protocol: TCP
            - name: https
              containerPort: 443
              protocol: TCP
          resources:
            limits:
              cpu: 200m
              memory: 2000Mi
            requests:
              cpu: 50m
              memory: 500Mi
          volumeMounts:
              mountPath: /application/scripts
          securityContext: {}
      restartPolicy: Always
      terminationGracePeriodSeconds: 30
      dnsPolicy: ClusterFirst
      serviceAccountName: caddy
      serviceAccount: caddy
      securityContext: {}
      imagePullSecrets:
        - name: regcred
      schedulerName: default-scheduler
  strategy:
    type: RollingUpdate
    rollingUpdate:
      maxUnavailable: 25%
      maxSurge: 25%
  revisionHistoryLimit: 10
  progressDeadlineSeconds: 600
   "admin":{
      "disabled":false,
      "enforce_origin":true,
      "listen":"localhost:2019",
      "origins":[
         "caddy-api:8080",
         "localhost:2019",
         "127.0.0.1:2019"
   "apps":{
      "http":{
         "servers":{
            "hocoos":{
               "listen":[
                  ":443"
               "routes":[
                     "@id":"magic.hocoos.cafe",
                     "handle":[
                           "handler":"subroute",
                           "routes":[
                                 "handle":[
                                       "handler":"rewrite",
                                       "strip_path_prefix":"/api/auth"
                                       "handler":"reverse_proxy",
                                       "upstreams":[
                                             "dial":"web-api:5000"
                                 "match":[
                                       "path":[
                                          "/api/auth/*"
                           "routes":[
                                 "handle":[
                                       "strip_path_prefix":"/api/web"
                                       "upstreams":[
                                 "match":[
                                       "path":[
                                          "/api/web/*"
                           "routes":[
                                 "handle":[
                                       "upstreams":[
                                             "dial":"front-vue:3000"
                                 "match":[
                                       "path":[
                     "match":[
                           "host":[
                              "magic.hocoos.cafe"
                     "terminal":true
                     "@id":"admin.hocoos.cafe",
                     "handle":[
                           "routes":[
                                 "handle":[
                                       "upstreams":[
                                 "match":[
                                       "path":[
                                          "/api/auth/*"
                           "routes":[
                                 "handle":[
                                       "upstreams":[
                                 "match":[
                                       "path":[
                                          "/api/web/*"
                           "routes":[
                                 "handle":[
                                       "upstreams":[
                                             "dial":"front-admin:3006"
                                 "match":[
                                       "path":[
                     "match":[
                           "host":[
                              "admin.hocoos.cafe"
                     "terminal":false
                     "handle":[
                           "routes":[
                                 "handle":[
                                       "upstreams":[
                                 "match":[
                                       "path":[
                                          "/api/web/*"
                     "terminal":false
                     "handle":[
                           "routes":[
                                 "handle":[
                                       "upstreams":[
                                             "dial":"front-site-vue:3001"
                                 "match":[
                                       "path":[
                     "match":[
                           "not":[
                                 "host":[
                                    "magic.hocoos.cafe"
                                 "host":[
                                    "admin.hocoos.cafe"
                     "terminal":false
                     "handle":[
                           "routes":[
                                 "handle":[
                                       "upstreams":[
                                 "match":[
                                       "path":[
                                          "/api/auth/*"
                     "terminal":false
      "tls":{
         "automation":{
            "on_demand":{
               "ask":"http://caddy-controller:8080/api/check",
               "rate_limit":{
                  "burst":20,
                  "interval":2
            "policies":[
                  "issuers":[
                        "ca":"",
                        "module":"internal"
                  "on_demand":false,
                  "storage":{
                     "address":"redis-master:6379",
                     "aes_key":"",
                     "db":0,
                     "host":"redis-master",
                     "key_prefix":"cloudflare",
                     "module":"redis",
                     "password":"password",
                     "port":"6379",
                     "timeout":5,
                     "tls_enabled":false,
                     "tls_insecure":true,
                     "value_prefix":"cloudflare"
                  "subjects":[
                     "*.hocoos.site"
                  "issuers":[
                        "ca":"https://acme-v02.api.letsencrypt.org/directory",
                        "challenges":{
                           "http":{
                              "disabled":true
                        "email":"hocoos@hocoos.com",
                        "module":"acme"
                  "on_demand":true,
                  "subjects":[
   "logging":{
      "logs":{
         "default":{
            "level":"DEBUG"
   "storage":{
      "aes_key":"",
      "db":0,
      "key_prefix":"caddytlsprod",
      "module":"redis",
      "port":"6379",
      "timeout":5,
      "value_prefix":"caddy-storage-redis"
We are attempting to do a split management between custom certificate stored on redis for specific wildcard domain and on_demand R3 Lets Encrypt certificates for every other domain. So far we have achieved multiple results, while none of them are what we are looking for.
There is no concrete error or valuable log, however when we attempted to split the policies, caddy kept “searching” for certificates using the
web.site.com->*.site.com->*.*.com->*.*.*
schema when not expected to.
We tried setting up the TLS store in different directories as such:
Redis Key Prefix: cloudflare
1.
  -> cloudflare/certificates/*.hocoos.site/*.hocoos.site.crt
  -> cloudflare/certificates/*.hocoos.site/*.hocoos.site.key
  -> cloudflare/certificates/*.hocoos.site/*.hocoos.site.json
      *.hocoos.site.json:
	"sans": [
		"hocoos.site",
        "*.hocoos.site"
2.
  -> cloudflare/certificates/*.hocoos.site.crt/certificates/*.hocoos.site.crt
  -> cloudflare/certificates/*.hocoos.site.crt/certificates/*.hocoos.site.key
The other option we tried to pursue is utilizing the policy’s get_certificate directive to pull certificartes from a remote server , while attempting this with a storage block pointing to redis inside of the policy we didnt recieve any errors with the directive but no calls were made to our remote server.
When we removed the storage block we recieved the following error from caddy:
loading http app module: provision http: getting tls app: loading tls app module: decoding module config: tls: json: unknown field "get_certificate"
None
Please upgrade to v2.5.0!
You can remove this, it’ll always match all requests.
I think that’s because get_certificate was only added with v2.5.0-beta.1, but you’re on v2.4.6.
Sounds like you want to manage a wildcard cert for *.hocoos.site?
You never wrote in your config to tell Caddy you specifically want a wildcard cert. It needs to appear somewhere in your routes as a top-level host matcher, or in apps > tls > certificates > automate.
You did put it in apps > tls > automation > policies > subjects, but that’s just a “subject matcher”, i.e. “use this policy when trying to automate this cert” but you never told Caddy to automate that cert.
Hey francislavoie,
Sorry for not informing about the progress earlier - busy days, but we managed to achieve the desired results of managing and delivering 3 different certificates with Caddy(R3, CloudFlare Origin, CloudFlare sni) thanks to your advice, we were using the policy section in a wrong way.
On a slightly different topic, is there any known WAF integration/module that will work with Caddy and wont interfere with the certificates mentioned above? I’ve found something called Coraza that is supposed to be a Caddy module, but the documentation on it is very limiting.
Maybe @jptosso can help
