I’m trying to configure an ssl certificate for a webpage running behind caddy with certbot. I have configured caddy to redirect to 443 on the webpage server however certbot and browsers fail to access the webpage. As the webpage does not use SSL yet I don’t think caddy can forward to it, so I get an HTTP 502 error when I go to the domain I have configured. If I can’t access the webpage without an SSL cert, and to get an SSL cert I need to have access to the webpage, how do I proceed? Can someone guide me to the answer to the chicken and the egg?
Network setup is 443 is the only port open on the network which redirects to caddy, and caddy distributes depending on the domain name used (I have another server behind caddy that works fine (subdomain1) so i think caddy is fine and it is just certbot and caddy that clash)
i kept getting error 502 if i pasted it directly in here so here is a link
https://www.mediafire.com/file/7wk00ibjdpvlfik/log-redacted.txt/file
Installed using the Ubuntu packages
Ubuntu 20.04.6 LTS, x86
caddy.service file
# caddy.service
# for your installation.
Type=notify
# domain name.
debug # for the log file above only
subdomain1.domain.net {
reverse_proxy 192.168.2.5:8096
subdomain2.domain.net {
reverse_proxy 192.168.2.4:443
Note that i have replaced the true domain names with subdomain 1 and 2, i have replaced them universally and i can not share the true domain names as their unknowingness is one line of security i have setup. subdomain1 works fine but subdomain2 is the one that doesnt work with certbot (im not saying subdomain1 works with certbot, im saying everything is fine with subdomain1)
