I will be brief here with the explanation because it has been 2 years on this and now I have an opportunity to show caddyserver. I have a client that has about 50 domains all inside a server. He has several developers that are very reluctant to use caddyserver on the server, to the point that they only use Apache because it comes by default with Cpanel / WHMCS.
Currently they changed from CentOS to Ubuntu with the Cpanel server. I am trying to run Caddy on the server, but every time the domain is access, cpanel is the one that grabs it first before caddyserver even sees the traffic. How can I do something along the lines of:
Hey Cpanel, do not handle THIS specific sub domain or domain and let caddyserver handle it.
Can Caddyserver work together in a server that apache is also in?
The Caddyserver configuration is like this:
http_port 8080
https_port 8443
api.testsite.com {
root * /var/www/api
tls luisalvaradox@gmail.com
header Access-Control-Allow-Origin "*"
header Access-Control-Allow-Methods "POST, GET, OPTIONS, PUT, DELETE"
header Access-Control-Allow-Headers "*"
header Server "CaddyServer 1.0"
encode gzip zstd
try_files {path} {path}/index.php
php_fastcgi unix//opt/cpanel/ea-php81/root/usr/var/run/23450a7cf9fcb8aeaf115a274c59fb54f0db770d.sock
@cachedFiles {
path *.ico *.css *.js *.gif *.jpg *.jpeg *.png *.webp *.svg *.woff *.woff2
header @cachedFiles Cache-Control max-age=31536000
Caddy version is 2.7.6
from the PPA it was installed.
