Hi I’m not sure this is the right place to post this because I think it’s a Cloudflare problem but I see many posts here using the same Caddy + Cloudflare for SaaS setup that’s why I’m asking.
Anyway, I am running a Caddy server on ‘supa.blog’, it has SSL setup for both wildcard subdomains and main domain (*.supa.blog and supa.blog)
I am using Cloudflare for SaaS to create custom hostnames for my customers and let them CNAME to a subdomain on my server.
Cloudflare successfully generates the certificate and custom host name but I get a SSL error
I suspect this is because the SSL cert served from my custom host name (blog.notodog.com) doesn’t have Subject Alternative Names for actual the CNAME forwarded domain (*.supa.blog, and supa.blog)
However I am not sure how to add these SANs onto the SSL cert Cloudflare generates for my Custom Hostname. It looks like this feature is only for enterprise customers, which doesn’t make much sense.
How are all of the people using Cloudflare for SaaS serving their subdomains on customer’s custom domains if they SSL certificate doesn’t have SANs for their own apps subdomains/domain?
Could someone point me in right direction
Custom image of caddy-docker-proxy with xcaddy module for Cloudflare
Docker
I run through docker compose
version: '3.9'
db:
container_name: db
image: postgres:latest
restart: always
expose:
- 5432
- POSTGRES_DB=supadb
- POSTGRES_USER=postgres
- POSTGRES_PASSWORD=postgres
- './data/db:/var/lib/postgresql/data'
- djangonetwork
nginx:
image: jonasal/nginx-certbot:latest
- 443:443
depends_on:
- web
restart: "always"
links:
- web:web
- djangonetwork
- CERTBOT_EMAIL
env_file:
- ./nginx-certbot.env
- ./conf.d:/etc/nginx/conf.d
- ./nginx_secrets:/etc/letsencrypt
- ./staticfiles:/staticfiles
web:
build: .
command: sh -c "gunicorn notobackend.wsgi:application --bind 0.0.0.0:8000"
restart: always
- "8000:8000"
- djangonetwork
depends_on:
- db
links:
- db:db
env_file:
- .env
djangonetwork:
driver: bridge
nginx_secrets:
static_volume:
