Hello,
I am quite new to Caddy. I am currently using Caddy for reverse proxy and would now want to use it as a webserver for a website of mine that is running on a different virtual machine on the same network.
1. Caddy version (caddy version): v2.2.1
I am running Caddy on a virtual machine.
VM is running Ubuntu 20.04 LTS
Refer to the Caddy docs for more information:
The Caddyfile — Caddy Documentation
vpn.pttxfre.local {
reverse_proxy https://10.222.0.50 {
tls_insecure_skip_verify
utode.pttxfre.com {
reverse_proxy {
to https://10.222.0.4
I would want to use it as a webserver for a website of mine whose application files are on a different virtual machine on the same network. How do I properly configure the Caddyfile so that I can use the Caddy webserver to run that website that is on another computer on the same network?
My website is seated on a VM whose IP is 10.222.0.12 running on a certain port 5000.
Location of website files is /home/pttxfre/mypttxfre
My Caddy server is on the same network with an IP 10.222.0.20
This is the configuration that I have come up with and would like to add to my Caddyfile but am not so sure bout it
10.222.0.12:5000 { //ip and port for the website
root * /home/pttxfre/mypttxfre //location of website files
What could be the correct configuration?
Thanks
