Hi @francislavoie thanks for your response. Was held up with few other things and hence could not apply your recommendations.
After removing the transport section from the json, DoH is still not working with the above configuration.
Pasting the configuration again for the sake of completeness
"admin": {
"disabled": true
"logging": {
"logs": {
"default": {
"level": "ERROR",
"writer": {
"output": "file",
"filename": "/var/log/caddy/caddy.log",
"roll_size_mb": 10,
"roll_keep_days": 3
"apps": {
"http": {
"servers": {
"srv0": {
"listen": [":443"],
"routes": [
"match": [
"host": ["abc.domain.com"]
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"handler": "vars",
"root": ""
"match": [
"path": ["/admin*"]
"handle": [
"handler": "reverse_proxy",
"upstreams": [
"dial": "127.0.0.1:8080"
"match": [
"path": ["/doh-dns-query"]
"handle": [
"upstreams": [
"dial": "127.0.0.1:53"
"handle": [
"handler": "static_response",
"status_code": 404
"terminal": true
"tls": {
"automation": {
"policies": [
"subjects": ["abc.domain.com"]
Had configured caddy to emit DEBUG
logs. Below are some logs from the log file
{"level":"debug","ts":1730652364.4467366,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"127.0.0.1:53","duration":0.620585975,"request":{"remote_ip":"10.150.133.2","remote_port":"55934","client_ip":"10.150.133.2","proto":"HTTP/2.0","method":"POST","host":"abc.domain.com","uri":"/doh-dns-query","headers":{"X-Forwarded-For":["10.150.133.2"],"X-Forwarded-Host":["abc.domain.com"],"Accept-Language":["*"],"User-Agent":["Chrome"],"Content-Type":["application/dns-message"],"Priority":["i"],"X-Forwarded-Proto":["https"],"Content-Length":["128"],"Accept":["application/dns-message"],"Accept-Encoding":["identity"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"abc.domain.com"}},"error":"context canceled"}
{"level":"debug","ts":1730652406.8176937,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"127.0.0.1:53","duration":1.994096531,"request":{"remote_ip":"10.150.133.2","remote_port":"55980","client_ip":"10.150.133.2","proto":"HTTP/2.0","method":"POST","host":"abc.domain.com","uri":"/doh-dns-query","headers":{"Accept-Language":["*"],"Accept-Encoding":["identity"],"Content-Type":["application/dns-message"],"X-Forwarded-For":["10.150.133.2"],"X-Forwarded-Proto":["https"],"Content-Length":["128"],"Accept":["application/dns-message"],"User-Agent":["Chrome"],"Priority":["i"],"X-Forwarded-Host":["abc.domain.com"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"abc.domain.com"}},"error":"context canceled"}
{"level":"debug","ts":1730652408.3910503,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"127.0.0.1:53","duration":1.019060835,"request":{"remote_ip":"10.150.133.2","remote_port":"55984","client_ip":"10.150.133.2","proto":"HTTP/2.0","method":"POST","host":"abc.domain.com","uri":"/doh-dns-query","headers":{"Content-Type":["application/dns-message"],"X-Forwarded-Host":["abc.domain.com"],"Content-Length":["128"],"Accept-Language":["*"],"User-Agent":["Chrome"],"Accept-Encoding":["identity"],"Accept":["application/dns-message"],"Priority":["i"],"X-Forwarded-For":["10.150.133.2"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"abc.domain.com"}},"error":"context canceled"}
{"level":"debug","ts":1730652413.1081638,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"127.0.0.1:53","duration":2.095746432,"request":{"remote_ip":"10.150.133.2","remote_port":"55981","client_ip":"10.150.133.2","proto":"HTTP/2.0","method":"POST","host":"abc.domain.com","uri":"/doh-dns-query","headers":{"X-Forwarded-For":["10.150.133.2"],"X-Forwarded-Proto":["https"],"Priority":["u=0, i"],"Content-Length":["128"],"Accept":["application/dns-message"],"Accept-Language":["*"],"User-Agent":["Chrome"],"Accept-Encoding":["identity"],"Content-Type":["application/dns-message"],"X-Forwarded-Host":["abc.domain.com"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"abc.domain.com"}},"error":"context canceled"}
{"level":"debug","ts":1730652413.1082864,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"127.0.0.1:53","duration":2.096128941,"request":{"remote_ip":"10.150.133.2","remote_port":"55981","client_ip":"10.150.133.2","proto":"HTTP/2.0","method":"POST","host":"abc.domain.com","uri":"/doh-dns-query","headers":{"Content-Type":["application/dns-message"],"Priority":["u=0, i"],"User-Agent":["Chrome"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["abc.domain.com"],"Accept-Encoding":["identity"],"Accept":["application/dns-message"],"Accept-Language":["*"],"X-Forwarded-For":["10.150.133.2"],"Content-Length":["128"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"abc.domain.com"}},"error":"context canceled"}
{"level":"debug","ts":1730652415.7297163,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"127.0.0.1:53","duration":2.06867819,"request":{"remote_ip":"10.150.133.2","remote_port":"55981","client_ip":"10.150.133.2","proto":"HTTP/2.0","method":"POST","host":"abc.domain.com","uri":"/doh-dns-query","headers":{"User-Agent":["Chrome"],"Content-Type":["application/dns-message"],"X-Forwarded-For":["10.150.133.2"],"X-Forwarded-Host":["abc.domain.com"],"Accept-Encoding":["identity"],"Priority":["u=0, i"],"Content-Length":["128"],"Accept":["application/dns-message"],"Accept-Language":["*"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"abc.domain.com"}},"error":"context canceled"}
{"level":"debug","ts":1730652415.729837,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"127.0.0.1:53","duration":2.069042816,"request":{"remote_ip":"10.150.133.2","remote_port":"55981","client_ip":"10.150.133.2","proto":"HTTP/2.0","method":"POST","host":"abc.domain.com","uri":"/doh-dns-query","headers":{"Content-Length":["128"],"Accept-Language":["*"],"Content-Type":["application/dns-message"],"Priority":["u=0, i"],"X-Forwarded-For":["10.150.133.2"],"X-Forwarded-Proto":["https"],"Accept":["application/dns-message"],"User-Agent":["Chrome"],"Accept-Encoding":["identity"],"X-Forwarded-Host":["abc.domain.com"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"abc.domain.com"}},"error":"context canceled"}
{"level":"debug","ts":1730652415.7298772,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"127.0.0.1:53","duration":2.068279482,"request":{"remote_ip":"10.150.133.2","remote_port":"55981","client_ip":"10.150.133.2","proto":"HTTP/2.0","method":"POST","host":"abc.domain.com","uri":"/doh-dns-query","headers":{"Accept-Encoding":["identity"],"Content-Type":["application/dns-message"],"Priority":["u=0, i"],"User-Agent":["Chrome"],"Content-Length":["128"],"Accept":["application/dns-message"],"Accept-Language":["*"],"X-Forwarded-For":["10.150.133.2"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["abc.domain.com"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"abc.domain.com"}},"error":"context canceled"}
{"level":"debug","ts":1730652415.730409,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"127.0.0.1:53","duration":2.069064629,"request":{"remote_ip":"10.150.133.2","remote_port":"55981","client_ip":"10.150.133.2","proto":"HTTP/2.0","method":"POST","host":"abc.domain.com","uri":"/doh-dns-query","headers":{"Content-Length":["128"],"User-Agent":["Chrome"],"Accept-Encoding":["identity"],"X-Forwarded-Proto":["https"],"Content-Type":["application/dns-message"],"Accept":["application/dns-message"],"Accept-Language":["*"],"X-Forwarded-For":["10.150.133.2"],"X-Forwarded-Host":["abc.domain.com"],"Priority":["u=0, i"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"abc.domain.com"}},"error":"context canceled"}
Also tried the dig
command locally to ensure the dns is listening on port 53.
dig @127.0.0.1 -p 53 yahoo.com
; <<>> DiG 9.18.28-1~deb12u2-Debian <<>> @127.0.0.1 -p 53 yahoo.com
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 3073
;; flags: qr rd ra; QUERY: 1, ANSWER: 6, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1232
; COOKIE: 4507ce7c2092d331 (echoed)
;; QUESTION SECTION:
;yahoo.com. IN A
;; ANSWER SECTION:
yahoo.com. 1274 IN A 98.137.11.163
yahoo.com. 1274 IN A 74.6.231.20
yahoo.com. 1274 IN A 98.137.11.164
yahoo.com. 1274 IN A 74.6.231.21
yahoo.com. 1274 IN A 74.6.143.26
yahoo.com. 1274 IN A 74.6.143.25
;; Query time: 8 msec
;; SERVER: 127.0.0.1#53(127.0.0.1) (UDP)
;; WHEN: Sun Nov 03 17:24:01 UTC 2024
;; MSG SIZE rcvd: 200
