Hi, so basically I have my home hub setup set to listen on port 8123 while I have a subdomain (let’s say abc.example.com) that points to my router public ip address.
So far I have a setup in my caddyfile that serves only the subdomain (abc.example.com { proxy / localhost:8123 }) and it works well.
But when I’m trying to add a configuration for serving 10.0.0.16 (private ip of my devuce) to other lab devices in my network, I cannot access any interface anymore until I revert the configuration.
Do you have an idea how can that be done?
Can you post the configuration (you can sanitize the hostname / IPs if needed)?. I’m running a single caddy instance serving both internal and external sites with no issues.
localhost {
websocket
header_upstream Host {host}
header_upstream X-Forwarded-For {remote}
domain.tld {
tls email
log /var/log/access.log {
rotate_size 50
rotate_age 90
rotate_keep 5
errors /var/log/error.log {
rotate_size 50
rotate_age 90
rotate_keep 5
header / {
Strict-Transport-Security "max-age=31536000; includeSubdomains"
X-Frame-Options "DENY"
Referrer-Policy "same-origin"
proxy / localhost:8123 {
websocket
If I delete the localhost {} section it works, but only on the public domain.
Post your config inside of code blocks, using backticks, like this: `
Much easier to read
Sorry about that, corrected.
In your second section, you have your proxy directives in a block ( {} ) but in your localhost section you don’t
websocket
vs
websocket
If these are the same, you can specify multiple hostname for a single definition, like
localhost, domain.tld {
They are not using the same certificate though… how can I make sure that localhost will not use my domain.tld certificate?
It shouldn’t matter. Caddy should use whatever certificate matches. Now you will run into issues if it can’t get one issued by LE, or one isn’t available, but if one already exists / one can be requested, there won’t be an issue. I have many such config sections, works just fine. I have a wildcard for domain.com and in.domain.com
# Wiki
https://wiki.domain.com, https://wiki.in.domain.com {
import defaults
proxy / srv+https://_https._tcp.wiki.in.domain.com {
import ../templates/proxy-defaults.cf
I tried to add localhost, domain.tld.
Still getting the message: “404 Site 10.0.0.x is not served on this interface” when trying to go to 10.0.0.x.
What do you get in your logs?
Nothing regarding those hits. Not in access neither in error logs.
The site label needs to match the requested host.
The requested host, in a modern browser, is based on what you put in the URL bar.
If you type 10.0.0.x in your browser URL bar, your site label in the Caddyfile needs to be 10.0.0.x or Caddy won’t be able to make the association.
