Hello, I am using caddy as a reverse proxy for my home server and am interested in using chevereto to share some family photos etc and things that we’d prefer to self-host.
I would install chevereto on a separate server from caddy and prefer to access it as a subdirectory eg. mydomain.com/chevereto or something but I’d be happy even if I got it to work with a subdomain like chevereto.mydomain.com.
I think part of the issue is that chevereto uses mod_rewrite to make pretty urls and I’m not sure how to configure caddy to handle that.
I saw a couple other posts on here regarding sites with mod_rewrite but they all have a bunch of complex regex statements and I’m hoping my problem is more simple than that.
When going to
mydomain.com/chevereto, the website resolves but the URL gets rewritten tomydomain.com/loginwhich does not exist and I get 404. -
When going to
chevereto.mydomain.comit simply times out and gives page cannot be displayed. -
When going to
http://localipthe website displays and works perfectly. -
Relevant resources:
Here is the.htaccessfile that chevereto uses.
I also tried adding this example caddy file I found for chevereto, but I think this is just if you are running caddy and chevereto on the same server, not using caddy as proxy. At least, I wasn’t able to get the syntax right and caddy wouldn’t start.
Lastly, here is my caddyfile:
mydomain.com
ext .html .htm
root /caddy/www
gzip
tls me@email.com
log /caddy/log/access.log {
rotate_size 3
rotate_age 90
rotate_keep 25
header / {
proxy /chevereto http://10.0.0.177 {
chevereto.mydomain.com {
log /caddy/log/chevereto.log {
rotate_size 3
rotate_age 90
rotate_keep 25
gzip
tls me@email.com
proxy / http://10.0.0.177/ {
I should also mention: I am using CADDY 0.10.10
