v2.4.0-beta.1 => /src/caddy
Host OS: Linux SMP Debian 4.19.132-1 (2020-07-24) x86_64 GNU/Linux
Docker Base Image: caddy:2.0.0-builder along with GitHub - caddy-dns/cloudflare: Caddy module: dns.providers.cloudflare · GitHub
sudo docker-compose -f caddy-compose.yml up -d
caddy-compose.yml
version: "3.7"
build: ./dns-dockerfile
hostname: caddy
- MY_DOMAIN=$MY_DOMAIN
- CLOUDFLARE_API_TOKEN=$CLOUDFLARE_API_TOKEN
- /data/caddy/data:/data
- /data/caddy/config:/config
default:
external:
Dockerfile
FROM caddy:2.0.0-builder AS builder
RUN caddy-builder \
github.com/caddy-dns/cloudflare
FROM caddy:2.0.0
key_type rsa4096
(proxy_template) {
www.{$MY_DOMAIN} {$MY_DOMAIN} {
reverse_proxy /.well-known/matrix/* https://matrix.{$MY_DOMAIN} {
import proxy_template
matrix.{$MY_DOMAIN}, dimension.{$MY_DOMAIN}, element.{$MY_DOMAIN}, jitsi.{$MY_DOMAIN} {
reverse_proxy matrix-nginx-proxy:8080
matrix.{$MY_DOMAIN}:8448 {
reverse_proxy matrix-nginx-proxy:8448
The way my setup works is is that a request that goes through my caddy server will be redirected to an nginx server (the reasoning for this is complicated) and then it is forwarded to my matrix server (which is just a normal server).
What I ideally want is the connection between the client and caddy to be protected with SSL. However, I don’t care about encrpyting the connection between caddy and nginx. Now when caddy is forwarding the request to nginx, it is throwing an error since caddy is making an https request when nginx expects http.
Nginx throws the following error to me:
error:1408F10B:SSL routines:ssl3_get_record:wrong version number
Looking at this answer on stackoverflow https://stackoverflow.com/questions/50840101/curl-35-error1408f10bssl-routinesssl3-get-recordwrong-version-number/50842202, it looks like the solution is that the proxy should use HTTP CONNECT to make sure that it is not using SSL when proxying to nginx.
Basically sending an http request to caddy works. Since caddy just forwards an http request to nginx and it doesn’t throw an error. But I want to connection between caddy and client to be https but connection between caddy and nginx to be http.
And for some reason I am not facing this problem when requesting matrix.mydomain. The problem only happens when requesting matrix.mydomain:8448. So the problem only occurs on port 8448 and not on port 80.
Is there anyway to do this with Caddy?
Here’s the error from nginx: error:1408F10B:SSL routines:ssl3_get_record:wrong version number
I don’t get any new logs in Caddy when I make this request so nothing to add there
