Using caddy as a proxy to Cockpit
Hello community! I am trying to run cockpit behind caddy. I 've seen this post that mentions how to properly set it up.
The problem is that after 5’ the connection terminates.
What I see after 5’ in the cockpit interface is:
Disconnected
Server has closed the connection.
Reconnect
It looks like, the web socket times out after 5’ and is not kept alive. I tried to keep it alive with options like
                tls_insecure_skip_verify
                keepalive 2h
                keepalive_interval 30s
                keepalive_idle_conns 100
                keepalive_idle_conns_per_host 10
but this didn’t work either. Is something else I should put there?
v2.10.0
deb [signed-by=/usr/share/keyrings/caddy-stable-archive-keyring.gpg] https://dl.cloudsmith.io/public/caddy/stable/deb/debian any-version main
deb-src [signed-by=/usr/share/keyrings/caddy-stable-archive-keyring.gpg] https://dl.cloudsmith.io/public/caddy/stable/deb/debian any-version main
Run directly on the OS level.
Debian GNU/Linux trixie/sid
run through regular systemd mechanism inside the debian package
Type=notify
my.domain {
    @allowed remote_ip my.external.ip
    handle @allowed {
        reverse_proxy my.internal.ip9090 {
                keepalive 2h
    respond 404
There’s no timeout for websockets
  • stream_timeout is a duration value after which streaming requests such as WebSockets will be forcibly closed at the end of the timeout. This essentially cancels connections if they stay open too long. A reasonable starting point might be 24h to cull connections older than a day. Default: no timeout.
Are you sure the termination of the connection is by Caddy and not by the network or upstream?
I am connecting practically on localhost. I alias my IP/port with a name, so that I can connect without having to remember the cockpit port. So it shouldn’t be a network issue.
Moreover, when I connect directly, i.e. using 192.168.1.7:9090 there’s no problem at all.
When I connect through caddy, it connects and after 5 minutes I need to force reload. When I reload I don’t need to re-login but still it is very annoying.
I can see that the default value of stream_timeout is “no timeout”. But this is not related, what other issue could it be?
Thank you for your attention btw.
