Using basic auth for different permissions (folder is protected and browsable, subfolders are not)
1. Caddy version (caddy version): Latest
Ubuntu 20.04
sudo service caddy start
N/A
# domain name.
recording.bpsdassist.org.au {
	#root * /usr/share/caddy
	root * /var/www/html
	# Enable the static file server, and browsing of a folder.
	file_server browse
	# New password hashes are made with caddy hash-password.
	basicauth /tasks/* {
		Bob <CREDENTIALS> # Admin, can browse all folders
		Brett <CREDENTIALS> # Normal person, can browse subfolders
	# php_fastcgi localhost:9000
	handle_errors {
		@404 {
			expression {http.error.status_code} == 404
		rewrite @404 /404.html
What I would like to try and do, is to have two levels of access.
The file structure is from the root:
  1. /tasks
  2. /tasks/task1/file.txt (there could be many variations of task1 names)
For 1. I can do, using basicauth for /tasks/* , and the entry in the config you can see is file_server browse.
What I’m not sure though, is how I could do 2. I don’t know the foldernames that have been generated in advance, but they would look like:
In other words, an admin can browse the tasks folder with their login.
Otherwise, a normal person that knows to navigate to /tasks/task1 can access that subfolder to browse. I would prefer if that is with it’s own basicauth password, but it’s okay if not.
Adding this below the first basicauth entry
basicauth /tasks/*/* { Brett <Hash> }
I can’t do this because of having two basicauth entries. It then overwrites the first entry, and doesn’t work anyway I don’t think.
I’m thinking the file server basics resources may help below, perhaps I could have the admins use /tasks/ which is a redirect, and normal users access it with the base of /task/ externally.
You can use handle blocks for this. With handle, only the first matching handle will run, so if one with a longer path matcher gets matched first, the next will be ignored.
handle /tasks/tastk1/* {
	basicauth {
		Bob <pass>
handle /tasks/* {
	basicauth {
		Alice <pass>
	# Optional fallback if none of the above matched
That does sound perfect, with the idea of matching and order being able to stack things.
With your
	basicauth {
		Bob <pass>
Example, would it be possible to have that catch all subfolders of tasks/ ?
Because it wouldn’t be known what exists at the time
Yes, it’s possible to match on /tasks/*/* which is a “globular match”
The actual rules for the globs is explained here (sourced from the Go stdlib):
(Note that it unfortunately doesn’t support ** globs to select multiple path segments, so that’ll depend on what you need).
Sorry, but /tasks// does not seem to match, or at least match a handle path with basic auth.
I tried the following:
        file_server browse
# Access to the subfolders only, does not work. Examples:
# /tasks/test/
# /tasks/test/file.txt
        handle /tasks/*/* {
                basicauth {
                        lowaccess <CREDENTIAL>
# Fall back to admin auth checking, still works.
        handle /tasks/* {
                basicauth {
                        Brett <CREDENTIAL>
With the above config lowaccess basicauth never works, being prompted again.
Is that problem to do with a multiple path segment like you mentioned? And could I get around it by using a path_regexp mentioned just below your doc reference?
Yeah, you can use path_regexp.
I’ll dig deeper to understand why that matcher didn’t work for you.
I’ve used the following as a temporary solution, but it feels pretty clunky - I have to duplicate the admin users into the higher folder. It also relies on me putting a prefix on each sub folder so I can match them in the handle.
The order that these are in the config file didn’t seem to make a difference, and if I didn’t duplicate the users, the admins wouldn’t be able to view the actual notes - just browse the folders.
# inside a path... {
# Low level person access, duplicated admin users so they can access here too. (otherwise the admins couldn't access here)
file_server browse
# These people can view individual notes, but can't browse the root folder.
        handle /tasks/note-prefix-* {
                basicauth {
                        lowaccess hashpwd
                        anotherlowaccess hashpwd
                        admin hashpwd
                        anotheradmin hashpwd
# Base admin access, they can browse the base folder.
        handle /tasks/* {
                basicauth {
			admin hashpwd
You can use Caddyfile snippets to deduplicate lists of credentials you’re putting in multiple places.
You’ve only copied a part of your config, so I don’t know how to comment on any other part of that.
Not much else in the rest of the config, but a snippet for the “admins” would help with the duplication.
config follows:
# domain name.
	file_server browse
                basicauth {
                        lowaccess <hashpwd>
                        anotherlowaccess <hashpwd>
                        admin <hashpwd>
                        anotheradmin <hashpwd>
        handle /tasks/* {
                basicauth {
			admin <hashpwd>
