1. Output of caddy version:
na
Run as a service.
Ubuntu 22.04.1 Caddy v2.5.2
Paste command here.
service caddy start
For my question not NA.
Not yet made. Because I don’ t know if it is possible.
Paste your config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
I have 2 computers. The first runs caddy as a webserver. The other one is the application server with php applications. My question is, is it possible to use/connect/start the php applications on the application server from the caddy webserver without using reverse_proxy but perhaps using the command file_server? If there is a solution, where perhaps can I find a example.
NA
I looked at the php_fastcgi documentation but I couldn’t find any answers.
NA
