Hi,
I’m migrating an existing nginx server configuration to Caddy and encountered a problem. My use-case is quite unorthodox - The purpose of Caddy is to serve as a transparant “fallback server”. It first tries to proxy all requests to a local upstream server. If this server returns any erronous status code (5xx/4xx) I then reverse-proxy to an original server based on a x-original-host header which already exists in the original traffic. In nginx this worked by setting a location with proxy_pass that has error_page set to a second location.
In Caddyfile I tried multiple options but I can’t seem to get it right.
When falling back through the inner reverse-proxy I get 400. Debug logs show that this 400 appear to come directly from the second upstream handling. I believe this might have to do with copy_response copying the wrong response or something. But generally I would really appreciate it if someone can review my configuration and see if it even makes sense. Some forum reading tells me that reverse_proxy in Caddy is a terminating handler, meaning it might not be entirely supported to do my use case?
Seen here - falling back, but alwats returning 400
{"level":"debug","ts":1763411953.2119687,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"chatgpt.com:443","total_upstreams":1}
{"level":"debug","ts":1763411953.219413,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"{http.request.header.x-original-host}:443","duration":0.007207787,"request":{"remote_ip":"192.168.194.71","remote_port":"45724","client_ip":"192.168.194.71","proto":"HTTP/2.0","method":"POST","host":"chatgpt.com","uri":"/ces/statsc/flush","headers":{"Cookie":["REDACTED"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Ch-Ua-Model":["\"\""],"Oai-Language":["en-US"],"X-Forwarded-Host":["aim-public-apps-proxy-fallback"],"X-Real-Ip":["192.168.194.71"],"Sec-Ch-Ua-Full-Version-List":["\"Chromium\";v=\"142.0.7444.162\", \"Google Chrome\";v=\"142.0.7444.162\", \"Not_A Brand\";v=\"99.0.0.0\""],"Sec-Ch-Ua":["\"Chromium\";v=\"142\", \"Google Chrome\";v=\"142\", \"Not_A Brand\";v=\"99\""],"X-Aim-Plugin-Installed":["true"],"Content-Type":["application/json"],"Via":["2.0 Caddy"],"Oai-Device-Id":["7fb4d345-dc4e-4f52-80f3-530ae758be92"],"Sec-Fetch-Site":["same-origin"],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Ch-Ua-Full-Version":["\"142.0.7444.162\""],"X-Forwarded-Proto":["https"],"Sec-Ch-Ua-Bitness":["\"64\""],"Accept":["*/*"],"Sec-Ch-Ua-Platform-Version":["\"15.7.2\""],"Referer":["https://chatgpt.com/"],"Content-Length":["188"],"Accept-Language":["en-US,en;q=0.9"],"Upgrade":[""],"Connection":[""],"Oai-Client-Version":["prod-7b4ad770564e1a05033d9481af8a607f0f63bc7b"],"Sec-Ch-Ua-Arch":["\"arm\""],"Sec-Ch-Ua-Platform":["\"macOS\""],"Sec-Fetch-Dest":["empty"],"Sec-Fetch-Mode":["cors"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/142.0.0.0 Safari/537.36"],"X-Forwarded-For":["192.168.194.71"],"Priority":["u=1, i"],"Origin":["https://chatgpt.com"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"aim-public-apps-proxy-fallback"}},"headers":{"Server":["cloudflare"],"Date":["Mon, 17 Nov 2025 20:39:13 GMT"],"Content-Type":["text/html"],"Content-Length":["557"],"Cf-Ray":["9a0209441f87f9c6-TLV"]},"status":400}
v2.10.2
Caddy is running in k8s deployment with the latest image.
alpine image from the official docker hub 2.10.2-alpine
/usr/bin/caddy run --config /etc/caddy/Caddyfile
I tried many things. a couple are listed here
- nested reverse_proxy directives.
- invoke-based
:443 {
tls /etc/certificates/cert.crt /etc/certificates/cert.key
reverse_proxy http://local-reverse-proxy.service.local:443 {
header_up Upgrade {header.Upgrade}
header_up Connection {header.Connection}
header_up Host {host}
# Streaming based options https://caddyserver.com/docs/caddyfile/directives/reverse_proxy#streaming
stream_timeout 24h
stream_close_delay 5s
# Intercept error responses from upstream
@error status 400 401 402 403 404 405 406 408 409 410 411 412 413 414 415 416 421 429 500 501 502 503 504 505 507
handle_response @error {
log_append * "fallback_status" "fallback-to-upstream"
# Check if x-original-host header exists
@has_original_host header x-original-host *
handle @has_original_host {
reverse_proxy {header.x-original-host}:443 {
tls
tls_server_name {header.x-original-host}
header_up Host {header.x-original-host}
# No x-original-host header, just pass through the error from the reverse-proxy (probably 400)
copy_response
&(app-proxy) {
reverse_proxy {http.request.header.x-original-host}:443 {
tls
tls_server_name {http.request.header.x-original-host}
header_up Host {http.request.header.x-original-host}
handle_response {
copy_response
:443 {
output stdout
format json
level debug
route {
log_append "fallback_status" "before-reverse-proxy"
# Instead of reverse_proxy here, invoke the fallback route
invoke @has_original_host app-proxy
# No x-original-host, pass through error
copy_response
