I would like to ask for your help. I don’t know how to set reverse proxy by URI instead of subdomain.
So far I have been using subdomains for reverse proxy on the services running on my local network. I have these proxies where everything works fine:
- https://gitea.blabla.com:3000 → 127.0.0.1:3100
- https://nas.blabla.com → 192.168.1.17:8860
Configuration:
gitea.blabla.com:3000 {
reverse_proxy 127.0.0.1:3100
nas.blabla.com {
@allowed remote_ip 192.168.0.0/16
# PERMIT ALL: @allowed remote_ip 0.0.0.0/0
handle @allowed {
reverse_proxy 192.168.1.17:8860 {
tls
tls_insecure_skip_verify
# Fallback for otherwise not matched handles
abort
But I would like to set the reverse proxy to work according to URI:
- https://blabla.com/gitea → 127.0.0.1:3000
- https://blabla.com/nas → 192.168.111.8860
My configuration that doesn’t work:
blabla.com {
handle_path /gitea {
reverse_proxy http://127.0.0.1:3100
handle_path /nas {
reverse_proxy https://192.168.1.17:8860 {
tls
Result:
When I type in the browser https://blabla.com/gitea I get the page with Gitea, but the page is broken. I see texts and fields but without any page design/formatting. When I click on the login I get a blank page with this address https://blabla.com/user/login?redirect_to=%2f.
In the case of NAS https://walda.cz/nas, I get immediately a blank page with the address https://walda.cz/redirect.html?count=0.4314695115592255.
Question:
I would like to ask you if it is possible to use a reverse proxy in this way, if I did some mistake in configuration or it is related to setting on Gitea and NAS, …
Thank you.
Caddy version:
Caddy is running via docker-compose on Raspberry Pi:
❯ cat docker-compose.yaml
version: "3"
image: caddy:2.6.2
- ./Caddyfile:/etc/caddy/Caddyfile:rw
- ./data:/data
- ./config:/config
- TZ=Europe/Rome
restart: always
- 443:443
network_mode: "host"
OS:
❯ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=debian
