Use Port 80 only for ACME, not for serving a website?
I have a working caddy reverse proxy with auto tls as it is recommended. But I want it to use port 80 only when doing ACME, otherwise not.
While not doing ACME, it should just not listen at all.
install caddy package, write simple " hostname { reverse_proxy 127.0.0.1:1234 }" config. Run using included systemd unit.
Have firewall only allow incoming port 80 from external, not 443.
I want Caddy to handle ACME http-01 but not the site reachable to the outside.
Use DNS challenge!
I can’t, I don’t have DNS access for crazy reasons.
Debian package on stable. X86_64
How would that even work? The HTTP-01 challenge requires access to:
http://<YOUR_DOMAIN>/.well-known/acme-challenge/<TOKEN>
That means port 80 has to be open and listening.
By default, Caddy uses port 80 only for the HTTP-01 challenge and to redirect to HTTPS. If you don’t want port 80 to be in use at all, you can disable it entirely and Caddy will then switch to using TLS-ALPN-01 instead. That challenge only uses port 443 and doesn’t depend on port 80 at all.
I somehow missed this:
hostname {
   @acme path /.well-known/acme-challenge/*
   handle @acme {
   abort
This should only forward the ACME path to your backend and drop everything else.
Not quite the thing I think yet.
I do not want to forward the ACME challenge.
What I want:
  • Caddy handles the ACME challenge
    • via HTTP-01
    • on Port 80
  • Caddy forwards incoming TLS traffic
    • on Port 443
    • to the backend
  • Caddy discards any requests
    • On Port 80
      • That aren’t the requests from the ACME Provider
OT: The ratelimiting here is really extreme. waiting half an hour between replies is daunting.
Sorry, but it’s necessary since we’ve been attacked by spam bots several times in the past where the volume was overwhelming – hundreds of spam replies and topics within an hour or two. So we limit new accounts until they grow in trust levels.
