Use of Locahost causes caddy to start on :80
V2
fbd9515
windows 10
Caddyfile with Localhost
localhost:16655 {
          output file d:\caddy\access564.log
        respond "this is a caddy2 server"
adapt json
  "logging": {
    "logs": {
      "log0": {
        "writer": {
          "filename": "d:\\caddy\\access564.log",
          "output": "file"
        "include": [
          "http.log.access.log0"
  "apps": {
    "http": {
      "servers": {
        "srv0": {
          "listen": [
            ":16655"
          "routes": [
              "match": [
                  "host": [
                    "localhost"
              "handle": [
                  "handler": "subroute",
                  "routes": [
                      "handle": [
                          "body": "this is a caddy2 server",
                          "handler": "static_response"
              "terminal": true
          "logs": {
            "logger_names": {
              "localhost:16655": "log0"
without localhost
:16655 {
adapt json
  "logging": {
    "logs": {
      "log0": {
        "writer": {
          "output": "file"
        "include": [
  "apps": {
    "http": {
      "servers": {
        "srv0": {
          "listen": [
            ":16655"
          "routes": [
              "handle": [
          "logs": {
            "logger_names": {
              ":16655": "log0"
If I load the caddyfile with localhost:16655 I get an error as port 80 is in use. If I just use a caddyfile without localhost and just :16655 , it works fine.
D:\caddy>curl localhost:2019/load -X POST -H "Content-Type: application/json" -d @caddyfile_withlocalhost.json
{"error":"loading config: loading new config: http app module: start: tcp: listening on :80: listen tcp :80: bind: Only one usage of each socket address (protocol/network address/port) is normally permitted."}
Answered here:
http_port does not work in Caddy 2.
The following Caddyfile reproduces the problem:
localhost:8001 {
reverse_proxy localhost:8000
I believe the expected behaviour of your given Caddyfile is:
  • Serve localhost via HTTPS on port 8001
  • Redirect regular HTTP on the default port (80) to the specified port
Try serving explicitly HTTP, e.g. http://localhost:8001
Cheers! Thanks a lot.
