okeehou
(Okeehou)
April 16, 2018, 9:04am
1
Hello, I got a problem when config http.browser with a domain name.
I us this config in Caddyfile and I can access my folder on web.
http://0.0.0.0.:12345 {
root /some/folder
browse /files
But if I use the below config, and restart caddy, it failed to restart.
https://mysites.domain {
root /some/folder
browse /files
gzip
tls myemail@myemail.com
I want to use my domain with https instead of IP:Port to access the folder.
What should I do? Thanks!
tobya
(Toby Allen)
April 17, 2018, 6:03pm
2
Is this your full caddyfile?
What version of caddy are you using?
What error did you get when it failed to start?
Use -log /somefile.log or -log stdout on the command line to get a system log
okeehou
(Okeehou)
April 18, 2018, 2:23am
3
Thank you for replying me.
My caddy version:
root@aaaaaa:~# caddy -version
Caddy 0.10.10 (non-commercial use only)
My full caddyfile:
root@aaaaaa:~# cat /etc/caddy/Caddyfile
https://sub1.mysite.domain {
gzip
proxy / localhost:someport
tls email@email.com
https://sub2.mysite.domain {
gzip
tls email@email.com
https://mysite.domain {
tls email@email.com
root /some/folder/wordpress
gzip
fastcgi / /run/php/php7.0-fpm.sock php
rewrite {
if {path} not_match ^\/wp-admin
to {path} {path}/ /index.php?_url={uri}
#http://IP:Port {
#root /some/folder2/files
#browse /
https://sub3.mysite.domain {
browse /
gzip
tls email@email.com
I ran systemctl restart caddy and get this:
root@aaaaaa:~# systemctl status caddy
● caddy.service - Caddy HTTP/2 web server
Active: failed (Result: exit-code) since Tue 2018-04-17 22:11:08 EDT; 5min ago
Docs: https://caddyserver.com/docs
Process: 29671 ExecStart=/usr/local/bin/caddy -log stdout -agree=true -conf=/etc/caddy/Caddyfile -root=/var/tmp (code=exited, status=1/FAILURE)
Main PID: 29671 (code=exited, status=1/FAILURE)
Apr 17 22:11:08 aaaaaa systemd[1]: Started Caddy HTTP/2 web server.
Apr 17 22:11:08 aaaaaa systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Apr 17 22:11:08 aaaaaa systemd[1]: caddy.service: Unit entered failed state.
Apr 17 22:11:08 aaaaaa systemd[1]: caddy.service: Failed with result 'exit-code'.
matt
(Matt Holt)
April 18, 2018, 8:17pm
4
We’re looking for Caddy’s logs, not systemd’s (as usual, systemd is getting in the way and not being helpful and possibly contributing to the problem). What’s in the Caddy log?
okeehou
(Okeehou)
April 19, 2018, 7:43am
5
I beg your pardon, but it seems that I could not find any Caddy logs elsewhere. I use log /var/log/caddy-err.log but it failed to restart Caddy so there is no log being written. Would you mind to show me how to get these logs? Thanks.
abiosoft
(Abiola Ibrahim)
April 19, 2018, 7:58am
6
What is the output of journalctl -u caddy ?
okeehou
(Okeehou)
April 27, 2018, 3:34am
7
Sorry, my issue has been resolved. It seems something wrong with the old caddy version (same here ), and I was rate limited cuz I tried to many times. I upgrade to v0.10.14 now, and the issue was fixed. Thank you guys for helping me!
