We manage custom domains and I am moving from in-house certificate management to Caddy. I want to use existing certificates and let Caddy do the renewals. For the new domains, Caddy can do complete certificate management (issuing + renewal).
What I have done is copied the existing certs pem and private key pem in Caddy’s storage location and named the keys in the format understood by Caddy.
However, Caddy doesn’t seem to be recognizing the certificates and provisioning new certificates.
I am trying to use existing certificates for existing domains, rather than re-creating new certificates for them when the request is routed through Caddy, so that I can avoid hitting Letsencrypt rate limits(300 certs in 3 hours)
On container start - loading certificate into cache
{"level":"info","ts":1681196084.2337275,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"https"}
{"level":"info","ts":1681196084.234672,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1681196084.234672,"logger":"tls","msg":"cleaning storage unit","description":"&{3ns 60ns 0xc000351520}"}
{"level":"debug","ts":1681196084.2347155,"logger":"storage.mysql.sql","msg":"select `key` from certmagic_data where `key` like 'ocsp%'"}
{"level":"info","ts":1681196084.234737,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
{"level":"debug","ts":1681196084.2347834,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":true}
{"level":"info","ts":1681196084.2347996,"logger":"http.log","msg":"server running","name":"https","protocols":["h1","h2","h3"]}
{"level":"debug","ts":1681196084.2348254,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
{"level":"info","ts":1681196084.23483,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"debug","ts":1681196084.2348452,"logger":"http","msg":"starting server loop","address":"[::]:9999","tls":false,"http3":false}
{"level":"info","ts":1681196084.2348526,"logger":"http.log","msg":"server running","name":"health-check","protocols":["h1","h2","h3"]}
{"level":"info","ts":1681196084.2349665,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1681196084.2349763,"msg":"serving initial configuration"}
{"level":"debug","ts":1681196084.2352035,"logger":"storage.mysql.sql","msg":"select `key` from certmagic_data where `key` like 'certificates%'"}
{"level":"debug","ts":1681196084.2452528,"logger":"storage.mysql.sql","msg":"select `key` from certmagic_data where `key` like 'certificates/acme-v02.api.letsencrypt.org-directory/maaiz.ptmn.com/maaiz.ptmn.com.json%'"}
{"level":"debug","ts":1681196084.2456384,"logger":"storage.mysql.sql","msg":"select `key` from certmagic_data where `key` like 'certificates/acme-v02.api.letsencrypt.org-directory/maaiz.ptmn.com/maaiz.ptmn.com.json%'"}
{"level":"debug","ts":1681196084.2460475,"logger":"storage.mysql.sql","msg":"select `key` from certmagic_data where `key` like 'certificates/acme-v02.api.letsencrypt.org-directory/maaiz.ptmn.com/maaiz.ptmn.com.json%'"}
{"level":"debug","ts":1681196084.2475772,"logger":"storage.mysql.sql","msg":"select `key` from certmagic_data where `key` like 'certificates/acme-v02.api.letsencrypt.org-directory/maaiz.ptmn.com/maaiz.ptmn.com.key%'"}
{"level":"debug","ts":1681196084.2479799,"logger":"storage.mysql.sql","msg":"select `key` from certmagic_data where `key` like 'certificates/acme-v02.api.letsencrypt.org-directory/maaiz.ptmn.com/maaiz.ptmn.com.key%'"}
{"level":"debug","ts":1681196084.2483592,"logger":"storage.mysql.sql","msg":"select `key` from certmagic_data where `key` like 'certificates/acme-v02.api.letsencrypt.org-directory/maaiz.ptmn.com/maaiz.ptmn.com.key%'"}
{"level":"debug","ts":1681196084.248756,"logger":"storage.mysql.sql","msg":"select `key` from certmagic_data where `key` like 'certificates/
{"level":"debug","ts":1681196084.256117,"logger":"storage.mysql.sql","msg":"select `key` from certmagic_data where `key` like 'certificates/acme-v02.api.letsencrypt.org-directory/maaiz.ptmn.com/maaiz.ptmn.com.crt%'"}
{"level":"debug","ts":1681196084.2565248,"logger":"storage.mysql.sql","msg":"select `key` from certmagic_data where `key` like 'certificates/acme-v02.api.letsencrypt.org-directory/maaiz.ptmn.com/maaiz.ptmn.com.crt%'"}
{"level":"debug","ts":1681196084.2568374,"logger":"storage.mysql.sql","msg":"SELECT value FROM certmagic_data WHERE `key_hash` = dc16c872b8eef199641f76c16385949b"}
{"level":"debug","ts":1681196084.2575946,"logger":"storage.mysql.sql","msg":"select `key` from certmagic_data where `key` like 'certificates/acme-v02.api.letsencrypt.org-directory/maaiz.ptmn.com/maaiz.ptmn.com.crt%'"}
On hitting domain - not using the existing certificate
{"level":"debug","ts":1681196258.0756476,"logger":"events","msg":"event","name":"tls_get_certificate","id":"7e00e2db-0bf2-4012-834a-fe1386f40391","origin":"tls","dataError":"json: unsupported type: proxyproto.Validator"}
{"level":"debug","ts":1681196258.0757575,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"maaiz.ptmn.com"}
{"level":"debug","ts":1681196258.0757627,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.postmanlabs-beta.com"}
{"level":"debug","ts":1681196258.0757658,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.com"}
{"level":"debug","ts":1681196258.0757685,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*"}
{"level":"debug","ts":1681196258.0757725,"logger":"tls.handshake","msg":"all external certificate managers yielded no certificates and no errors","remote_ip":"172.105.36.145","remote_port":"60842","sni":"maaiz.ptmn.com"}
{"level":"debug","ts":1681196258.0758367,"logger":"storage.mysql.sql","msg":"SELECT value FROM certmagic_data WHERE `key_hash` = 1b0f72132cbd71ce53d6800d0fac696d"}
{"level":"debug","ts":1681196258.0769823,"logger":"storage.mysql.sql","msg":"SELECT value FROM certmagic_data WHERE `key_hash` = d2834ecfc079ec0f668e7a99ff25bb42"}
{"level":"debug","ts":1681196258.078431,"logger":"tls","msg":"response from ask endpoint","domain":"maaiz.ptmn.com","url":"http://localhost:9999?domain=maaiz.ptmn.com","status":200}
{"level":"info","ts":1681196258.0784516,"logger":"tls.on_demand","msg":"obtaining new certificate","remote_ip":"172.105.36.145","remote_port":"60842","server_name":"maaiz.ptmn.com"}
{"level":"debug","ts":1681196258.0785513,"logger":"storage.mysql.sql","msg":"SELECT EXISTS(SELECT 1 FROM certmagic_data WHERE `key_hash` = dc16c872b8eef199641f76c16385949b)"}
{"level":"debug","ts":1681196258.079284,"logger":"storage.mysql.sql","msg":"SELECT EXISTS(SELECT 1 FROM certmagic_data WHERE `key_hash` = 1b0f72132cbd71ce53d6800d0fac696d)"}
caddy-2.6.4
Caddy alpine docker image
command: ["caddy", "run", "--config", "/config/caddy/caddy.json"]
Used kubernetes deployment
"apps": {
"http": {
"http_port": 80,
"servers": {
"https": {
"listen": [":443"],
"listener_wrappers": [{ "wrapper": "go_proxyproto" }, { "wrapper": "tls" }],
"routes": [
"handle": [
"handler": "reverse_proxy",
"transport": { "protocol": "http", "tls": {} },
"upstreams": [{ "dial": "localhost:9999" }]
"terminal": true
"tls_connection_policies": [{}]
"health-check": {
"listen": [":9999"],
"routes": [{ "handle": [{ "body": "OK", "handler": "static_response" }], "match": [{ "path": ["/"] }] }]
"tls": {
"automation": {
"on_demand": { "ask": "http://localhost:9999" },
"policies": [
"issuers": [{ "module": "acme", "account_key": "<private_key_pem>" }],
"on_demand": true,
"key_type": "rsa4096",
"disable_ocsp_stapling": true
"logging": { "logs": { "default": { "level": "DEBUG", "writer": { "output": "stdout" } } } },
"storage": { "module": "mysql", "dsn": "" }
