In minimum normal config of Caddyfile:
email your@email.com
sub.domain.org {
php_fastcgi 127.0.0.1:9000
root * /usr/local/www/
on_demand
with command caddy adapt --config Caddyfile --pretty
, it output json file as following:
"apps": {
"http": {
"servers": {
"srv0": {
"listen": [
":443"
"routes": [
"match": [
"host": [
"sub.domain.org"
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"handler": "vars",
"root": "/usr/local/www/"
"encodings": {
"gzip": {}
"handler": "encode",
"prefer": [
"gzip"
"handle": [
"handler": "static_response",
"headers": {
"Location": [
"{http.request.orig_uri.path}/"
"status_code": 308
"match": [
"file": {
"try_files": [
"{http.request.uri.path}/index.php"
"not": [
"path": [
"handle": [
"handler": "rewrite",
"uri": "{http.matchers.file.relative}"
"match": [
"file": {
"split_path": [
".php"
"try_files": [
"{http.request.uri.path}",
"{http.request.uri.path}/index.php",
"index.php"
"handle": [
"handler": "reverse_proxy",
"transport": {
"protocol": "fastcgi",
"split_path": [
".php"
"upstreams": [
"dial": "127.0.0.1:9000"
"match": [
"path": [
"*.php"
"handle": [
"handler": "file_server",
"hide": [
"./Caddyfile"
"terminal": true
"tls": {
"automation": {
"policies": [
"subjects": [
"sub.domain.org"
"issuers": [
"email": "your@email.com",
"module": "acme"
"module": "zerossl"
"on_demand": true
if the above can’t help you, please please please fill-up the HELP TEMPLATE
