Use Caddy for listen to all domains
Hi all,
I want to switch from Apache to Caddy.
I wondered how can I listen to all domains which point to my server with a CNAME record. Could you help me with a sample configuration file?
Thanks
Hi @Majid,
You can define a site that serves any hostname by leaving the hostname empty and specifying only the scheme or port.
Any of the example addresses here without an actual domain present are domain-agnostic: Caddyfile Concepts — Caddy Documentation
Refer to the structure of the Caddyfile for an idea of layout - you want to use one of those domain-agnostic addresses in the blue-highlighted “Site address” area when you write your configuration: Caddyfile Concepts — Caddy Documentation
You can find the documentation on the v2 Caddyfile below. I’d advise looking into the quick start guide, the full tutorial, and the concepts pages as good places to start.
Thank you @Whitestrake
I have changed my config to this:
:443 {
     root /var/www/html
     tls email@example.com
     gzip
     fastcgi / /run/php/php7.4-fpm.sock php {
         ext .php
         split .php
         index index.php
But when I trying to access a domain which points to this server I got this error:
curl: (35) error:14004438:SSL routines:CONNECT_CR_SRVR_HELLO:tlsv1 alert internal error
where is my doing wrong?
That looks like a Caddyfile for Caddy v1.
For reference, you do not need this block:
         ext .php
         split .php
         index index.php
The php preset does all of this for you, so that fastcgi configuration can just be one line.
As for the tlsv1 alert, that’s most likely happening when Caddy doesn’t have a certificate for the site you tried to access.
Since you haven’t told Caddy which domains you’re serving, it can’t get certificates in advance. Since it has no certificate, it sends none, aborting the connection.
You can configure Caddy to fetch brand new certs mid-request. This is called On-Demand TLS and is documented for v1 here: https://caddyserver.com/v1/docs/automatic-https#on-demand
