Use Caddy for external and internal access
I would like to use Caddy for external and internal access.
From outside my network, all DNS names point to a single IP (Caddy) that receives requests and reverse proxy internal services.
From inside my network, each service is a container with it’s own IP address and respective DNS name.
When accessing from outside my network, I will use the URL adguard.home.arpa and Caddy will automatically use HTTPS and reverse proxy from port 3000.
But when accessing from inside my network, if I use the URL adguard.home.arpa browser will go direct to container IP, without use HTTPS and certificate provided by Caddy besides the fact that I must then add port 3000 to URL.
Can I use another DNS name to use caddy internally? For example, using URL caddy.home.arpa/adguard to reach internal AdGuard by Caddy instead of adguard.home.arpa:3000 (directly).
If yes, how should be the respective Caddyfile block?
No errors, just blank pages or 403 errors on some tryouts.
Operating System: Debian GNU/Linux 12 (bookworm
Kernel: Linux 6.2.16-5-pve
apt clean && apt update && apt -y upgrade && apt -y install caddy
wget -q -O caddy "https://caddyserver.com/api/download?os=linux&arch=amd64&p=github.com%2Fcaddy-dns%2Fcloudflare"
cp caddy /usr/bin/caddy
# caddy.service
# for your installation.
Type=notify
        acme_ca https://acme-v02.api.letsencrypt.org/directory
        #acme_ca https://acme-staging-v02.api.letsencrypt.org/directory
(cloudflare) {
        tls username@domain {
                dns cloudflare <secret>
(vips_only) {
        @fuck_off_world {
                not remote_ip 10.111.111.0/24 201.100.100.100/32 201.101.101.101/32 186.102.102.102/32
        respond @fuck_off_world 403
pve.home.arpa {
        import cloudflare
        import vips_only
        reverse_proxy https://pve.home.arpa:8006 {
                        tls_insecure_skip_verify
adguard.home.arpa {
        import cloudflare
        import vips_only
        reverse_proxy http://adguard.home.arpa:3000
graylog.home.arpa {
        import cloudflare
        import vips_only
        reverse_proxy http://graylog.home.arpa:9000
caddy.home.arpa {
        import cloudflare
        import vips_only
        #handle /adguard/* {
        #       # The path still retains "/adguard"
        #       reverse_proxy http://adguard.home.arpa:3000
        #handle_path /adguard/* {
        #        # The path has the "/adguard" prefix stripped
I suggest doing something like adguard.caddy.home.arpa or something like that. Always easier to use subdomains for each app than subpaths. You can definitely configure Caddy to serve those sites.
Thanks @francislavoie , could got what I wanted and I think it becomes even better organized and accessible!
New Caddyfile (wip):
(cloudflare) {
(vips_only) {
        @fuck_off_world {
caddy.home.arpa {
        import cloudflare
        import vips_only
        respond "Caddy!"
*.caddy.home.arpa {
        import cloudflare
        import vips_only
        @adguard host adguard.caddy.home.arpa
        handle @adguard {
                #respond "AdGuard!"
        @graylog host graylog.caddy.home.arpa
        handle @graylog {
                #respond "Graylog!"
        @pve host pve.caddy.home.arpa
        handle @pve {
        # Fallback for otherwise unhandled domains
                abort
adguard.home.arpa {
        import cloudflare
        import vips_only
graylog.home.arpa {
        import cloudflare
        import vips_only
pve.home.arpa {
        import cloudflare
        import vips_only
