URI String Substitution working with 'respond' but not 'redir'
macOS 12.1 | Apple Silicon
./caddy start
N/A
http://localhost:8080 {
	@catalog {
		path */catalog/*
	handle @catalog {
		uri replace : ""
		@token path_regexp token (^\/.+\/)(catalog\/.+)
		#respond @token {re.token.2}
        redir @token https://library.org/{re.token.2}
	handle / {
		respond "Hello World"
I am trying to implement a redirect with a string substitution.
Existing URL: http://localhost:8080/scottsboro/catalog/scott:1004
Desired URL after Redirect: https://library.org/catalog/scott1004
In short from the original URL, I want to:
  1. Replace the semicolon with empty string
  2. Strip out the first part of the path keeping only catalog/*
My confusion stems from the fact that the above configuration works as intended for the commented out respond line. However, when that same @token is used in the redirect the regex is applied but the semicolon remains.
N/A
I tried handle_prefix but could not get it to match on */catalog/*.
N/A
I think the problem you’re having is that redir has a higher directive order than uri, so redir runs first. See the directive order here:
To get around this, you can use route to override the directive order. You could replace handle with route, or you could wrap the contents of that handle with a nested route – it depends whether you need the handle blocks to implement mutual exclusivity or not.
