Upgrading from caddy v2.9.0 to 2.10.0
Im trying to upgrade from caddy v2.9.0 to v2.10.0 using the following command:
sudo caddy upgrade
This command gets stuck at the two Info-messages described in section 2 “Error messages and/or full log output”.
What do I have to do in order to fix this? Never seen messages like this before when upgrading.
sudo caddy upgrade
2025/04/19 14:06:11.641	INFO	this executable will be replaced	{"path": "/usr/bin/caddy"}
2025/04/19 14:06:11.641	INFO	requesting build	{"os": "linux", "arch": "amd64", "packages": ["github.com/caddy-dns/netcup@v0.1.1"]}
When I run
caddy list-modules
it gives me this:
  Standard modules: 124
dns.providers.netcup
  Non-standard modules: 1
  Unknown modules: 0
sudo caddy version
v2.9.0 h1:rteY8N18LsQn+2KVk6R10Vg/AlNsID1N/Ek9JLjm2yE=
I think I built it myself. I can start it by running
sudo service caddy start
Ubuntu 22.04 LTS, Caddy not running in a docker environment
The caddy upgrade command uses our build server, which is currently struggling because too many people depend on it. We recommend you use xcaddy to build it yourself.
Ok thanks for the info.
Since the update isnt super important to me, I will just wait a few days until I’ll try again.
Its always crazy to see how fast you guys respond to new forum posts, thank you very much for helping us! =)
