Haringstad
(Jacco van Koll)
September 24, 2020, 1:52pm
1
I need some help with upgrading a rewrite from v1 to v2:
rewrite /api {
r (.*)
to /index.php?page=newznabapi&{query}
So, the above is the original v1 rewrite, that works like a charm. But with v2, I can’t find any way to make this work.
rewrite /api/ /index.php?page=newznabapi&{query}
Isn’t doing it. And I’ve been trying to get it work for 2 weeks now… But can’t… Please help?
Path matching in Caddy v2 is exact-match, meaning /api/ will only match exactly /api/. To match paths starting with /api/, then add a *, like this: /api/*. Or if the / is not necessary, you can do /api*.
Haringstad
(Jacco van Koll)
October 10, 2020, 3:38pm
3
Ok, I might be pretty stupid… But I cannot get this to work…
This is the v1 configuration:
http://spotweb.delaars12.loc {
ext .html .htm .php
root /opt/share/spotweb/
log /var/log/caddy/spotweb-local.log {
rotate_size 100
rotate_age 5
rotate_keep 5
fastcgi / 127.0.0.1:9001 php
rewrite /api {
r (.*)
Please, help??? The rewrite is very important…
What’s the full v2 Caddyfile you’ve tried? What errors did you see?
Haringstad
(Jacco van Koll)
October 11, 2020, 2:14pm
5
I Tried the following two:
root * /opt/share/spotweb/
try_files {path}.html {path}.php
rewrite /api* /index.php?page=newznabapi&{query}
php_fastcgi 127.0.0.1:9001
output file /var/log/caddy/spotweb.log
http://spotwebapi.delaars12.loc {
php_fastcgi 127.0.0.1:9001 {
index index.php
output file /var/log/caddy/spotweb-api.log
But both don’t work at all… It drives me crazy!
Hmm. That all looks okay to me. You can add the debug global option to get additional logging for the rewrites to see what’s happening. Add this at the top of your Caddyfile:
You can find the logs in Caddy’s stdout. You didn’t say how you’re running Caddy, so I’m not sure where that would be for your setup.
Haringstad
(Jacco van Koll)
October 12, 2020, 9:18am
7
I am running caddy with the following startup on Raspberry Pi 3b+ raspbian 10.4:
After=network.target
I will add the debug option and see what happens
Haringstad
(Jacco van Koll)
October 12, 2020, 2:17pm
8
Ok, boot me into a christmas-tree. It’s working now…
