Updating Caddy on Fedora 41
When attempting to update the Caddy package on Fedora 41, I am receiving the following error:
Transaction failed: Signature verification failed.
OpenPGP check for package "caddy-2.9.0-1.fc41.x86_64" (/var/cache/libdnf5/copr:copr.fedorainfracloud.org:group_caddy:caddy-3cb22e1f0b8f9807/packages/caddy-2.9.0-1.fc41.x86_64.rpm) from repo "copr:copr.fedorainfracloud.org:group_caddy:caddy" has failed: Problem occurred when opening the package.
v2.9.0 h1:rteY8N18LsQn+2KVk6R10Vg/AlNsID1N/Ek9JLjm2yE=
Fedora release 41
yum update
I’m not able to reproduce this error. Using a Fedora 41 container, I can enable the copr and install caddy without issue.
❯ podman run -it --rm fedora:41
[root@0cc3eb2c444b /]# dnf copr enable @caddy/caddy
 https://copr.fedorainfracloud.org/api_3/rpmrepo 100% |   4.8 KiB/s | 957.0   B |  00m00s
Enabling a Copr repository. Please note that this repository is not part
of the main distribution, and quality may vary.
The Fedora Project does not exercise any power over the contents of
this repository beyond the rules outlined in the Copr FAQ at
<https://docs.pagure.org/copr.copr/user_documentation.html#what-i-can-build-in-copr>,
and packages are not held to any quality or security level.
Please do not file bug reports about these packages in Fedora
Bugzilla. In case of problems, contact the owner of this repository.
Is this ok [y/N]: y
[root@0cc3eb2c444b /]# dnf install caddy
Updating and loading repositories:
 Fedora 41 openh264 (From Cisco) - x86_64        100% |   8.1 KiB/s |   6.0 KiB |  00m01s
 Copr repo for caddy owned by @caddy             100% |  19.1 KiB/s |   2.6 KiB |  00m00s
 Fedora 41 - x86_64                              100% |  12.6 MiB/s |  36.3 MiB |  00m03s
 Fedora 41 - x86_64 - Updates                    100% |   2.4 MiB/s |   7.7 MiB |  00m03s
Repositories loaded.
Package                   Arch   Version                   Repository                Size
Installing:
 caddy                    x86_64 2.9.0-1.fc41              copr:copr.fedorainfr  49.4 MiB
Installing dependencies:
 dbus                     x86_64 1:1.14.10-4.fc41          fedora                 0.0   B
 dbus-broker              x86_64 36-4.fc41                 fedora               382.8 KiB
 dbus-common              noarch 1:1.14.10-4.fc41          fedora                11.2 KiB
 device-mapper            x86_64 1.02.199-4.fc41           fedora               348.2 KiB
 device-mapper-libs       x86_64 1.02.199-4.fc41           fedora               414.7 KiB
 expat                    x86_64 2.6.4-1.fc41              updates              292.9 KiB
 kbd                      x86_64 2.6.4-4.fc41              fedora                 1.5 MiB
 kbd-legacy               noarch 2.6.4-4.fc41              fedora               567.1 KiB
 kbd-misc                 noarch 2.6.4-4.fc41              fedora                 2.5 MiB
 kmod                     x86_64 33-1.fc41                 fedora               235.5 KiB
 libcbor                  x86_64 0.11.0-2.fc41             fedora                73.9 KiB
 libfdisk                 x86_64 2.40.2-4.fc41             fedora               362.9 KiB
 libpkgconf               x86_64 2.3.0-1.fc41              fedora                78.2 KiB
 libseccomp               x86_64 2.5.5-2.fc41              fedora               173.3 KiB
 pkgconf                  x86_64 2.3.0-1.fc41              fedora                88.6 KiB
 pkgconf-m4               noarch 2.3.0-1.fc41              fedora                14.4 KiB
 pkgconf-pkg-config       x86_64 2.3.0-1.fc41              fedora               989.0   B
 systemd                  x86_64 256.10-1.fc41             updates               16.7 MiB
 systemd-pam              x86_64 256.10-1.fc41             updates                1.1 MiB
 xkeyboard-config         noarch 2.42-2.fc41               fedora                 6.5 MiB
Installing weak dependencies:
 cryptsetup-libs          x86_64 2.7.5-1.fc41              fedora                 2.3 MiB
 diffutils                x86_64 3.10-8.fc41               fedora                 1.6 MiB
 kmod-libs                x86_64 33-1.fc41                 fedora               147.2 KiB
 libbpf                   x86_64 2:1.4.7-1.fc41            updates              402.5 KiB
 libfido2                 x86_64 1.15.0-2.fc41             fedora               238.2 KiB
 libxkbcommon             x86_64 1.7.0-4.fc41              fedora               336.4 KiB
 qrencode-libs            x86_64 4.1.1-8.fc41              fedora               160.9 KiB
 systemd-networkd         x86_64 256.10-1.fc41             updates                2.1 MiB
 systemd-resolved         x86_64 256.10-1.fc41             updates              661.4 KiB
 systemd-udev             x86_64 256.10-1.fc41             updates               11.9 MiB
 tpm2-tss                 x86_64 4.1.3-3.fc41              fedora                 1.6 MiB
Transaction Summary:
 Installing:        32 packages
Total size of inbound packages is 28 MiB. Need to download 28 MiB.
After this operation, 102 MiB extra will be used (install 102 MiB, remove 0 B).
Is this ok [y/N]: y
[ 1/32] dbus-1:1.14.10-4.fc41.x86_64             100% |  35.2 KiB/s |   7.9 KiB |  00m00s
[ 2/32] libfdisk-0:2.40.2-4.fc41.x86_64          100% | 361.6 KiB/s | 159.8 KiB |  00m00s
[ 3/32] caddy-0:2.9.0-1.fc41.x86_64              100% |  14.0 MiB/s |  12.5 MiB |  00m01s
[ 4/32] libseccomp-0:2.5.5-2.fc41.x86_64         100% | 150.9 KiB/s |  70.2 KiB |  00m00s
[ 5/32] systemd-pam-0:256.10-1.fc41.x86_64       100% | 830.3 KiB/s | 376.9 KiB |  00m00s
[ 6/32] dbus-broker-0:36-4.fc41.x86_64           100% | 370.0 KiB/s | 171.7 KiB |  00m00s
[ 7/32] dbus-common-1:1.14.10-4.fc41.noarch      100% |  49.9 KiB/s |  14.7 KiB |  00m00s
[ 8/32] expat-0:2.6.4-1.fc41.x86_64              100% | 463.7 KiB/s | 114.5 KiB |  00m00s
[ 9/32] libxkbcommon-0:1.7.0-4.fc41.x86_64       100% | 489.1 KiB/s | 143.3 KiB |  00m00s
[10/32] libbpf-2:1.4.7-1.fc41.x86_64             100% | 798.3 KiB/s | 179.6 KiB |  00m00s
[11/32] kmod-libs-0:33-1.fc41.x86_64             100% | 151.7 KiB/s |  69.9 KiB |  00m00s
[12/32] systemd-0:256.10-1.fc41.x86_64           100% |   1.7 MiB/s |   5.4 MiB |  00m03s
[13/32] xkeyboard-config-0:2.42-2.fc41.noarch    100% | 711.2 KiB/s | 972.3 KiB |  00m01s
[14/32] cryptsetup-libs-0:2.7.5-1.fc41.x86_64    100% | 646.4 KiB/s | 532.7 KiB |  00m01s
[15/32] device-mapper-libs-0:1.02.199-4.fc41.x86 100% | 423.7 KiB/s | 177.1 KiB |  00m00s
[16/32] device-mapper-0:1.02.199-4.fc41.x86_64   100% | 295.4 KiB/s | 136.8 KiB |  00m00s
[17/32] qrencode-libs-0:4.1.1-8.fc41.x86_64      100% | 173.9 KiB/s |  61.7 KiB |  00m00s
[18/32] diffutils-0:3.10-8.fc41.x86_64           100% | 764.9 KiB/s | 405.4 KiB |  00m01s
[19/32] systemd-networkd-0:256.10-1.fc41.x86_64  100% | 845.7 KiB/s | 697.7 KiB |  00m01s
[20/32] systemd-resolved-0:256.10-1.fc41.x86_64  100% | 335.6 KiB/s | 301.4 KiB |  00m01s
[21/32] kbd-0:2.6.4-4.fc41.x86_64                100% | 996.8 KiB/s | 414.7 KiB |  00m00s
[22/32] kmod-0:33-1.fc41.x86_64                  100% |   1.1 MiB/s | 123.0 KiB |  00m00s
[23/32] kbd-legacy-0:2.6.4-4.fc41.noarch         100% |   1.2 MiB/s | 573.6 KiB |  00m00s
[24/32] pkgconf-pkg-config-0:2.3.0-1.fc41.x86_64 100% |  35.4 KiB/s |  10.0 KiB |  00m00s
[25/32] pkgconf-0:2.3.0-1.fc41.x86_64            100% | 134.1 KiB/s |  45.2 KiB |  00m00s
[26/32] pkgconf-m4-0:2.3.0-1.fc41.noarch         100% |  56.6 KiB/s |  14.3 KiB |  00m00s
[27/32] kbd-misc-0:2.6.4-4.fc41.noarch           100% |   1.2 MiB/s |   1.7 MiB |  00m01s
[28/32] libpkgconf-0:2.3.0-1.fc41.x86_64         100% | 513.1 KiB/s |  38.5 KiB |  00m00s
[29/32] systemd-udev-0:256.10-1.fc41.x86_64      100% | 958.6 KiB/s |   2.3 MiB |  00m02s
[30/32] tpm2-tss-0:4.1.3-3.fc41.x86_64           100% |   1.9 MiB/s | 411.5 KiB |  00m00s
[31/32] libfido2-0:1.15.0-2.fc41.x86_64          100% | 410.6 KiB/s |  98.1 KiB |  00m00s
[32/32] libcbor-0:0.11.0-2.fc41.x86_64           100% | 176.3 KiB/s |  33.1 KiB |  00m00s
[32/32] Total                                    100% |   3.9 MiB/s |  28.1 MiB |  00m07s
[ 1/33] https://download.copr.fedorainfracloud.o 100% |  25.5 KiB/s | 994.0   B |  00m00s
[33/33] Total                                    100% |   3.9 MiB/s |  28.1 MiB |  00m07s
Importing OpenPGP key 0xD605147E:
 UserID     : "@caddy_caddy (None) <@caddy#caddy@copr.fedorahosted.org>"
 Fingerprint: 4A76F92FF6D40440F8FC4F36C52191B1D605147E
 From       : https://download.copr.fedorainfracloud.org/results/@caddy/caddy/pubkey.gpg
Is this ok [y/N]: y
The key was successfully imported.
[ 1/34] Verify package files                     100% | 438.0   B/s |  32.0   B |  00m00s
[ 2/34] Prepare transaction                      100% |   1.4 KiB/s |  32.0   B |  00m00s
[ 3/34] Installing libfdisk-0:2.40.2-4.fc41.x86_ 100% | 177.8 MiB/s | 364.1 KiB |  00m00s
[ 4/34] Installing libcbor-0:0.11.0-2.fc41.x86_6 100% |  73.5 MiB/s |  75.3 KiB |  00m00s
[ 5/34] Installing libpkgconf-0:2.3.0-1.fc41.x86 100% |  77.5 MiB/s |  79.3 KiB |  00m00s
[ 6/34] Installing pkgconf-0:2.3.0-1.fc41.x86_64 100% |  89.0 MiB/s |  91.1 KiB |  00m00s
[ 7/34] Installing pkgconf-m4-0:2.3.0-1.fc41.noa 100% |   0.0   B/s |  14.8 KiB |  00m00s
[ 8/34] Installing pkgconf-pkg-config-0:2.3.0-1. 100% |   0.0   B/s |   1.8 KiB |  00m00s
[ 9/34] Installing kmod-0:33-1.fc41.x86_64       100% |  78.1 MiB/s | 240.0 KiB |  00m00s
[10/34] Installing kbd-misc-0:2.6.4-4.fc41.noarc 100% |  79.4 MiB/s |   2.6 MiB |  00m00s
[11/34] Installing kbd-legacy-0:2.6.4-4.fc41.noa 100% |  43.0 MiB/s | 616.8 KiB |  00m00s
[12/34] Installing kbd-0:2.6.4-4.fc41.x86_64     100% | 260.1 MiB/s |   1.6 MiB |  00m00s
[13/34] Installing kmod-libs-0:33-1.fc41.x86_64  100% | 144.8 MiB/s | 148.3 KiB |  00m00s
[14/34] Installing xkeyboard-config-0:2.42-2.fc4 100% | 311.4 MiB/s |   6.5 MiB |  00m00s
[15/34] Installing expat-0:2.6.4-1.fc41.x86_64   100% | 288.1 MiB/s | 295.0 KiB |  00m00s
[16/34] Installing dbus-common-1:1.14.10-4.fc41. 100% | 797.1 KiB/s |  13.6 KiB |  00m00s
[17/34] Installing dbus-broker-0:36-4.fc41.x86_6 100% |  62.7 MiB/s | 385.3 KiB |  00m00s
[18/34] Installing dbus-1:1.14.10-4.fc41.x86_64  100% |   0.0   B/s | 124.0   B |  00m00s
[19/34] Installing libseccomp-0:2.5.5-2.fc41.x86 100% | 171.1 MiB/s | 175.2 KiB |  00m00s
[20/34] Installing systemd-pam-0:256.10-1.fc41.x 100% | 212.7 MiB/s |   1.1 MiB |  00m00s
[21/34] Installing systemd-0:256.10-1.fc41.x86_6 100% | 132.8 MiB/s |  16.9 MiB |  00m00s
>>> Running post-install scriptlet: systemd-0:256.10-1.fc41.x86_64
>>> Finished post-install scriptlet: systemd-0:256.10-1.fc41.x86_64
>>> Scriptlet output:
>>> Creating group 'systemd-journal' with GID 190.
>>> Creating group 'systemd-oom' with GID 999.
>>> Creating user 'systemd-oom' (systemd Userspace OOM Killer) with UID 999 and GID 999.
[22/34] Installing device-mapper-libs-0:1.02.199 100% | 203.0 MiB/s | 415.8 KiB |  00m00s
[23/34] Installing device-mapper-0:1.02.199-4.fc 100% | 171.8 MiB/s | 351.8 KiB |  00m00s
[24/34] Installing cryptsetup-libs-0:2.7.5-1.fc4 100% | 468.8 MiB/s |   2.3 MiB |  00m00s
[25/34] Installing systemd-udev-0:256.10-1.fc41. 100% |  47.2 MiB/s |  11.9 MiB |  00m00s
>>> Running post-install scriptlet: systemd-udev-0:256.10-1.fc41.x86_64
>>> Finished post-install scriptlet: systemd-udev-0:256.10-1.fc41.x86_64
>>> Scriptlet output:
>>> Created symlink '/etc/systemd/system/dbus-org.freedesktop.home1.service' → '/usr/li
>>> Created symlink '/etc/systemd/system/multi-user.target.wants/systemd-homed.service' �
>>> Created symlink '/etc/systemd/system/systemd-homed.service.wants/systemd-homed-activa
>>> Created symlink '/etc/systemd/system/dbus-org.freedesktop.oom1.service' → '/usr/lib
>>> Created symlink '/etc/systemd/system/multi-user.target.wants/systemd-oomd.service' �
>>> Created symlink '/etc/systemd/system/sysinit.target.wants/systemd-pstore.service' →
>>> Created symlink '/etc/systemd/system/multi-user.target.wants/remote-cryptsetup.target
>>> Running pre-install scriptlet: caddy-0:2.9.0-1.fc41.x86_64
>>> Finished pre-install scriptlet: caddy-0:2.9.0-1.fc41.x86_64
>>> Scriptlet output:
>>> Creating group 'caddy' with GID 998.
>>> Creating user 'caddy' (Caddy web server) with UID 998 and GID 998.
>>> Creating group 'systemd-coredump' with GID 997.
>>> Creating user 'systemd-coredump' (systemd Core Dumper) with UID 997 and GID 997.
>>> Creating group 'systemd-timesync' with GID 996.
>>> Creating user 'systemd-timesync' (systemd Time Synchronization) with UID 996 and GID
[26/34] Installing caddy-0:2.9.0-1.fc41.x86_64   100% | 488.8 MiB/s |  49.4 MiB |  00m00s
[27/34] Installing systemd-networkd-0:256.10-1.f 100% | 130.1 MiB/s |   2.1 MiB |  00m00s
[28/34] Installing systemd-resolved-0:256.10-1.f 100% |  54.1 MiB/s | 665.3 KiB |  00m00s
>>> Running post-install scriptlet: systemd-resolved-0:256.10-1.fc41.x86_64
>>> Finished post-install scriptlet: systemd-resolved-0:256.10-1.fc41.x86_64
>>> Scriptlet output:
>>> Created symlink '/etc/systemd/system/dbus-org.freedesktop.resolve1.service' → '/usr
>>> Created symlink '/etc/systemd/system/sysinit.target.wants/systemd-resolved.service' �
[29/34] Installing libxkbcommon-0:1.7.0-4.fc41.x 100% | 165.1 MiB/s | 338.1 KiB |  00m00s
[30/34] Installing libfido2-0:1.15.0-2.fc41.x86_ 100% |  21.3 MiB/s | 239.7 KiB |  00m00s
>>> Running pre-install scriptlet: tpm2-tss-0:4.1.3-3.fc41.x86_64
>>> Finished pre-install scriptlet: tpm2-tss-0:4.1.3-3.fc41.x86_64
>>> Scriptlet output:
>>> useradd: Warning: missing or non-executable shell '/usr/sbin/nologin'
[31/34] Installing tpm2-tss-0:4.1.3-3.fc41.x86_6 100% | 225.8 MiB/s |   1.6 MiB |  00m00s
[32/34] Installing qrencode-libs-0:4.1.1-8.fc41. 100% | 158.9 MiB/s | 162.7 KiB |  00m00s
[33/34] Installing diffutils-0:3.10-8.fc41.x86_6 100% | 530.1 MiB/s |   1.6 MiB |  00m00s
[34/34] Installing libbpf-2:1.4.7-1.fc41.x86_64  100% |   1.3 MiB/s | 403.4 KiB |  00m00s
>>> Running trigger-install scriptlet: systemd-0:256.10-1.fc41.x86_64
>>> Finished trigger-install scriptlet: systemd-0:256.10-1.fc41.x86_64
>>> Scriptlet output:
>>> Creating group 'systemd-network' with GID 192.
>>> Creating user 'systemd-network' (systemd Network Management) with UID 192 and GID 192
>>> Creating group 'systemd-resolve' with GID 193.
>>> Creating user 'systemd-resolve' (systemd Resolver) with UID 193 and GID 193.
Complete!
Are you able to reproduce this error on any other systems? Have you tried clearing the dnf cache (dnf clean all)?
dnf clean all does not resolve the issue.
What does your repo config look like? Here is the one that is generated for me when running dnf copr enable @caddy/caddy on F41.
[copr:copr.fedorainfracloud.org:group_caddy:caddy]
name=Copr repo for caddy owned by @caddy
baseurl=https://download.copr.fedorainfracloud.org/results/@caddy/caddy/fedora-$releasever-$basearch/
type=rpm-md
skip_if_unavailable=True
gpgcheck=1
gpgkey=https://download.copr.fedorainfracloud.org/results/@caddy/caddy/pubkey.gpg
repo_gpgcheck=0
enabled=1
enabled_metadata=1
Edit:
Went ahead and removed mine as it matches yours character for character.
Same issue for me.
This is the error that is generated when I run Software update:
package caddy-2.9.0-1.fc41.x86_64 cannot be verified and repo copr:copr.fedorainfracloud.org:group_caddy:caddy is GPG enabled: /var/cache/PackageKit/41/metadata/copr:copr.fedorainfracloud.org:group_caddy:caddy-41-x86_64/packages/caddy-2.9.0-1.fc41.x86_64.rpm could not be verified.
/var/cache/PackageKit/41/metadata/copr:copr.fedorainfracloud.org:group_caddy:caddy-41-x86_64/packages/caddy-2.9.0-1.fc41.x86_64.rpm: Verifying a signature using certificate 4A76F92FF6D40440F8FC4F36C52191B1D605147E (@caddy_caddy (None) <@caddy#caddy@copr.fedorahosted.org>):
  1. Certificate C52191B1D605147E invalid: certificate is not alive
    because: The primary key is not live
    because: Expired on 2024-10-07T09:36:31Z
  2. Key C52191B1D605147E invalid: key is not alive
    because: Expired on 2024-10-07T09:36:31Z: Verifying a signature using certificate 4A76F92FF6D40440F8FC4F36C52191B1D605147E (@caddy_caddy (None) <@caddy#caddy@copr.fedorahosted.org>):
  3. Certificate C52191B1D605147E invalid: certificate is not alive
  4. Key C52191B1D605147E invalid: key is not alive
    because: Expired on 2024-10-07T09:36:31Z: digest: SIGNATURE: NOT OK
I resolved this issue by updating the key.
I ran rpm -e gpg-pubkey-d605147e-5d9daa1f and then was able to install it fine.
That looks to have solved my issue, too.
Thanks!
