Unsure How to Configure DynamicDNS for Namecheap
I tried getting DynamicDNS set up for Namecheap, but since I'm hosting on Linux and can't download their program, I don't know what to do. I figured the API would be responsible for it all, but I couldn't find any confirmation for it. So I guess this is more of a question overall.
This is the main error, but I'm starting to think that the DynamicDNS directives aren't going to help me here.
Error: adapting config using caddyfile: parsing caddyfile tokens for 'dynamic_dns': wrong argument count or unexpected line ending after 'REDACTED API KEY', at /etc/caddy/Caddyfile:3
xcaddy build --with github.com/caddy-dns/namecheap --with github.com/mholt/caddy-dynamicdns
Arch Linux using Linux-LTS kernel, x86_64
Docker and Docker Compose
b. Service/unit/compose file:
I have only pasted the relevant information, which should be Caddy alone.
    image: caddy:latest
      - 443:443
      - 443:443/udp # Needed for HTTP/3.
      - /srv/caddy/caddy:/usr/bin/caddy  # Your custom build of Caddy.
      - /srv/caddy/Caddyfile:/etc/caddy/Caddyfile:ro
      - /srv/caddy/caddy-config:/config
      - /srv/caddy/caddy-data:/data
      EMAIL: "REDACTED"                 # The email address to use for ACME registration.
      LOG_FILE: "/data/access.log"
    extra_hosts: ["host.docker.internal:host-gateway"]
      caddy_net: {}
      dns:
      vaultwarden_net:
      homeassistant_net:
      teamspeak_net:
      nextcloud_net:
  caddy_net:
    external: true
  dns:
    ipam:
      config:
        - subnet: 172.50.0.0/16
  vaultwarden_net:
  homeassistant_net:
  teamspeak_net:
  nextcloud_net:
c. My complete Caddy config:
        dynamic_dns {
                provider namecheap "REDACTED API KEY"
                domains {
                        famdam.top
*.famdam.top {
        dns namecheap {
            api_key REDACTED
            user REDACTED
            api_endpoint https://api.namecheap.com/xml.response
            client_ip 139.60.65.236
        @vaultwarden host vaultwarden.famdam.top
        handle @vaultwarden {
            reverse_proxy vaultwarden:80
        @wireguard host wireguard.famdam.top
        handle @wireguard {
            reverse_proxy wireguard:80
        @pihole host pihole.famdam.top
        handle @pihole {
            reverse_proxy pihole:80
#        @srv-teamspeak-1 host teamspeak.famdam.top
#        handle @srv-teamspeak-1 {
#            reverse_proxy 192.168.1.60:9987
        @nextcloud-aio-mastercontainer host nextcloud.famdam.top
        handle @nextcloud-aio-mastercontainer {
            reverse_proxy host.docker.internal:11000
        # Fallback for otherwise unhandled domains
                abort
        # This setting may have compatibility issues with some browsers
        # (e.g., attachment downloading on Firefox). Try disabling this
        # if you encounter issues.
        encode zstd gzip
Sorry, not what you’re asking about, but it might help.
With NameCheap, you can easily update your dynamic DNS using curl.
Let’s say you have my-site.example.com defined in your NameCheap DNS as an A + Dynamic DNS Record. You can update it from your server with the following command:
curl "https://dynamicdns.park-your-domain.com/update?host=my-site&domain=example.com&password=DYNAMIC_DNS_PASSWORD"
Here, DYNAMIC_DNS_PASSWORD is the Dynamic DNS password you can find in your NameCheap portal.
To automate this, a simple cron job running the following:
curl -s "https://dynamicdns.park-your-domain.com/update?host=my-site&domain=example.com&password=DYNAMIC_DNS_PASSWORD" > /dev/null
will take care of it.
If you’d like to give it a try, you can find more details here:
I’ll try that. If there’s a way to do it in Caddy, I’d rather do that, but this will suffice for now. Thanks, timelordx.
This is wrong. There should be only 1 global options section, not 2.
Right. I got it corrected, thanks for pointing it out.
I came back to this and appear to have gotten it working. I’ll update it if I still have problems. The problem was with (me) how Caddy was parsing that directive. This is the correct Caddyfile:
        dynamic_dns {
                provider namecheap {
                        api_key redacted
                        user redacted
                domains {
                        famdam.top @
