v2.4.0-beta.1 h1:Ed/tIaN3p6z8M3pEiXWJL/T8JmCqV62FrSJCHKquW/I=
Inside a LXC container on ProxMox, behind FortiGate VM
Linux caddy01 5.4.103-1-pve #1 SMP PVE 5.4.103-1 (Sun, 07 Mar 2021 15:55:09 +0100) x86_64 GNU/Linux
systemctl restart caddy
# cat /etc/systemd/system/caddy.service
Environment="CLOUDFLARE_API_TOKEN=...."
ExecStart=/usr/local/bin/caddy-downloaded run --environ --config /etc/caddy/Caddyfile
ExecReload=/usr/local/bin/caddy-downloaded reload --config /etc/caddy/Caddyfile
#ProtectSystem=full
(dnstls) {
#define this token in systemd service file
(statics) {
redir /favicon* https://statics.tracks4africa.co.za{uri}
respond /robots.txt 200 {
body "User-agent: *
Allow: /
Allow: /media/users/images/
Disallow: /maps/africa/
Disallow: /maps/trips/
Disallow: /maps/corrections/
Disallow: /listings/advanced_search/
Disallow: /listings/getlisted/
Disallow: /listings/category_search/
Disallow: /listings/link/
Disallow: /listings/correction/
Disallow: /listings/photos/
Disallow: /listings/comments/
Disallow: /listings/media/
Disallow: /listings/map/
Disallow: /accounts/
close
import /etc/caddy/sites-enabled/*
/etc/caddy/sites-enabled# for i in *; do echo '-------'; echo $i ;echo "===========";/usr/local/bin/caddy-downloaded fmt $i;done
django_t4a_retailers.conf
#Caddyfile format for each of the vhosts
#InternalDomain
#ExternalDomain
retailers.tracks4africa.co.za {
import statics
output file /var/log/caddy/retailers.tracks4africa.co.za-access.log
reverse_proxy {
# django-2021-other01
to 10.131.32.30:50010
# stage-django-2021-other01
# localhost
header_up +USWGI_SCHEME https
# charset utf-8
# client_max_body_size 25M
django_t4a_t4a-2021-django.conf
#Caddyfile format
#This is specific to the stage.tracks4africa.co.za / tracks4africa.co.za only
#InternalDomain
tracks4africa.net {
import statics
import dnstls
output file /var/log/caddy/tracks4africa.net-access.log
#return 301 https://$host$request_uri
reverse_proxy {
# t4a-2021-django01
to 10.131.32.20:40001
# t4a-2021-django02
# stage-t4a-2021-django01
# charset utf-8
#ExternalDomain
import statics
output file /var/log/caddy/tracks4africa.co.za-access.log
reverse_proxy {
# t4a-2021-django01
# t4a-2021-django02
# charset utf-8
django_t4a_t4a-guide-app.conf
#InternalDomain
#ExternalDomain
t4a-guide-app.tracks4africa.co.za {
import statics
output file /var/log/caddy/t4a-guide-app.tracks4africa.co.za-access.log
reverse_proxy {
to 10.131.32.30:50007
# localhost
# charset utf-8
django_t4a_t4a_submission_api.conf
#InternalDomain
submission-api.tracks4africa.net {
import statics
import dnstls
output file /var/log/caddy/submission-api.tracks4africa.net-access.log
reverse_proxy {
to 10.131.32.30:60001
# localhost
# charset utf-8
#ExternalDomain
submission-api.tracks4africa.co.za {
import statics
output file /var/log/caddy/submission-api.tracks4africa.co.za-access.log
reverse_proxy {
# localhost
# charset utf-8
www_t4a.conf
www.tracks4africa.co.za {
redir https://tracks4africa.co.za permanent
seeing these in the log files lately:
"Unsolicited response received on idle HTTP channel " followed by page content.
I suspect it’s the monitoring services I’m using that checks for the HTTP 200 response and then closes the connection before the data was being transfered from the downstream Django
May 6 09:37:41 caddy01 caddy-downloaded[32321]: {“level”:“error”,“ts”:1620293861.1722639,“logger”:“http.log.error.log2”,“msg”:“EOF”,“request”:{“remote_addr”:“66.249.73.143:53685”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“tracks4africa.co.za”,“uri”:“/listings/item/w382336/samfya-marines-beach-lodge/”,“headers”:{“Accept”:[“text/html,application/xhtml+xml,application/signed-exchange;v=b3,application/xml;q=0.9,/;q=0.8”],“From”:[“googlebot(at)googlebot.com”],“User-Agent”:[“Mozilla/5.0 (Linux; Android 6.0.1; Nexus 5X Build/MMB29P) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.97 Mobile Safari/537.36 (compatible; Googlebot/2.1; +http://www.google.com/bot.html)”],“Accept-Encoding”:[“gzip, deflate, br”],“If-Modified-Since”:[“Sun, 02 May 2021 20:45:39 GMT”],“Amp-Cache-Transform”:[“google;v="1..7"”],“Connection”:[“keep-alive”]},“tls”:{“resumed”:false,“version”:772,“cipher_suite”:4865,“proto”:“”,“proto_mutual”:true,“server_name”:“tracks4africa.co.za”}},“duration”:90.77586902,“status”:502,“err_id”:“496phe1ba”,“err_trace”:“reverseproxy.statusError (reverseproxy.go:817)”}
May 6 09:37:43 caddy01 caddy-downloaded[32321]: {“level”:“error”,“ts”:1620293863.9625528,“logger”:“http.log.error.log2”,“msg”:“EOF”,“request”:{“remote_addr”:“62.119.69.92:10400”,“proto”:“HTTP/2.0”,“method”:“GET”,“host”:“tracks4africa.co.za”,“uri”:“/maps/w139076/”,“headers”:{“Accept”:[“text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,/;q=0.8,application/signed-exchange;v=b3;q=0.9”],“Sec-Fetch-Site”:[“same-origin”],“Sec-Fetch-Mode”:[“navigate”],“Referer”:[“https://tracks4africa.co.za/listings/item/w139076/konkiep-lapa-rest-camp-campsite/"],“Accept-Encoding”:["gzip, deflate, br”],“Cookie”:[“__cfduid=d1905de7b4975001d437b1505f22376781620293706; _ga=GA1.3.2015295586.1620293707; _gid=GA1.3.223497462.1620293707”],“User-Agent”:[“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.93 Safari/537.36”],“Sec-Ch-Ua-Mobile”:[“?0”],“Upgrade-Insecure-Requests”:[“1”],“Sec-Fetch-User”:[“?1”],“Sec-Fetch-Dest”:[“document”],“Accept-Language”:[“sv-SE,sv;q=0.9,en-US;q=0.8,en;q=0.7”],“Sec-Ch-Ua”:[“" Not A;Brand";v="99", "Chromium";v="90", "Google Chrome";v="90"”]},“tls”:{“resumed”:false,“version”:772,“cipher_suite”:4865,“proto”:“h2”,“proto_mutual”:true,“server_name”:“tracks4africa.co.za”}},“duration”:91.380005458,“status”:502,“err_id”:“a3urcgyrj”,“err_trace”:“reverseproxy.statusError (reverseproxy.go:817)”}
May 6 09:39:18 caddy01 caddy-downloaded[32321]: 2021/05/06 09:39:18 Unsolicited response received on idle HTTP channel starting with “\n\n\n\n\n\n<html lang="en">\n \n \n <meta charset="utf-8">\n <meta http-equiv="X-UA-Compatible" content="IE=edge">\n <meta name="viewport" content="width=device-width, initial-scale=1">\n \n \n \n<link rel="apple-touch-icon" sizes="57x57" href="https://static.tracks4africa.co.za/apple-touch-icon-57x57.png\”>\n<link rel="apple-touch-icon" sizes="60x60" href="https://static.tracks4africa.co.za/apple-touch-icon-60x60.png\“>\n<link rel="apple-touch-icon" sizes="72x72" href="https://static.tracks4africa.co.za/apple-touch-icon-72x72.png\”>\n<link rel="apple-touch-icon" sizes="76x76" href="https://static.tracks4africa.co.za/apple-touch-icon-76x76.png\“>\n<link rel="apple-touch-icon" sizes="114x114" href="https://static.tracks4africa.co.za/apple-touch-icon-114x114.png\”>\n<link rel="apple-touch-icon" sizes="120x120" href="https://static.tracks4africa.co.za/apple-touch-icon-120x120.png\“>\n<link rel="apple-touch-icon" sizes="144x144" href="https://static.tracks4africa.co.za/apple-touch-icon-144x144.png\”>\n<link rel="apple-touch-icon" sizes="152x152" href="https://static.tracks4africa.co.za/apple-touch-icon-152x152.png\“>\n<link rel="apple-touch-icon" sizes="180x180" href="https://static.tracks4africa.co.za/apple-touch-icon-180x180.png\”>\n<link rel="icon" type="image/png" href="https://static.tracks4africa.co.za/favicon-32x32.png\" sizes="32x32">\n<link rel="icon" type="image/png" href="https://static.tracks4africa.co.za/favicon-194x194.png\" sizes="194x194">\n<link rel="icon" type="image/png" href="https://static.tracks4africa.co.za/favicon-96x96.png\" sizes="96x96">\n<link rel="icon" type="image/png" href="https://static.tracks4africa.co.za/android-chrome-192x192.png\" sizes="192x192">\n<link rel="icon" type="image/png" href="https://static.tracks4africa.co.za/favicon-16x16.png\" sizes="16x16">\n<link rel="manifest" href="https://static.tracks4africa.co.za/manifest.json\“>\n<link rel="shortcut icon" href="https://static.tracks4africa.co.za/favicon.ico\”>\n<meta name="msapplication-TileColor" content="#da532c">\n<meta name="msapplication-TileImage" content="https://static.tracks4africa.co.za/mstile-144x144.png\“>\n<meta name="msapplication-config" content="https://static.tracks4africa.co.za/browserconfig.xml\”>\n<meta name="theme-color" content="#ffffff">\n\n \n \n <meta property="og:title" content="Tracks4Africa" />\n <meta property="og:type" content="company" />\n <meta property="og:url" content="https://tracks4africa.co.za/\" />\n <meta property="og:site_name" content="Tracks4Africa" />\n <meta property="fb:admins" content="100000128267084" />\n <meta property="fb:app_id" content="219545334764267" />\n <meta property="og:image" content="https://static.tracks4africa.co.za/images/t4a-logo.png\" />\n <link rel="img_src" href="https://static.tracks4africa.co.za/mages/t4a-logo.png\" />\n \n \n <meta name="format-detection" content="telephone=no" />\n\n Welcome to Tracks4Africa\n\n <link rel="stylesheet" type="text/css" \n href="https://static.tracks4africa.co.za/css/normalize.css\" media="screen, print">\n <link href="//maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap.min.css" rel="stylesheet">\n <link href="https://stackpath.bootstrapcdn.com/bootstrap/3.0.3/css/bootstrap-theme.min.css\" rel="stylesheet" media="screen">\n \n\n \n \n\n <link rel="stylesheet" type="text/css" \n href="https://static.tracks4africa.co.za/css/style3.css\" media="screen, print">\n <link rel="stylesheet" type="text/css" \n href="https://static.tracks4africa.co.za/css/page-header-middle.css\" media="screen, print">\n <link rel="stylesheet" type="text/css" \n href="https://static.tracks4africa.co.za/css/page-content.css\" media="screen, print">\n <link rel="stylesheet" type="text/css" \n "; err=
Googled.
