Unrecognized subdirective websocket
v2.0.0-beta9
nohup ./caddy &
exit
Ubuntu 18.04
d. My complete Caddyfile:
tunnel.mysite.com {
	reverse_proxy * localhost:8080 {
            websocket
            header_up X-Real-IP {http.request.remote}
            header_up X-Forwarded-For {http.request.remote}
            header_up X-Forwarded-Proto {http.request.scheme}
When I try to start caddy I see “unrecognized subdirective websocket”
For reference, I am implementing caddy per this post https://blog.alexellis.io/https-inlets-local-endpoints/ and converting from Caddy 1.x to 2.x
Thank you
Hi @petebytes, welcome to the Caddy community!
Caddy v2’s reverse proxy doesn’t have a websocket subdirective.
In Caddy v1, the websocket preset configures two upstream headers, Connection and Upgrade.
You will need to specify these headers manually using request header placeholders (i.e. {http.request.header.FIELD-NAME}) and the header_up subdirective for v2’s reverse_proxy.
https://caddyserver.com/v1/docs/proxy#presets
Home · caddyserver/caddy Wiki · GitHub
Thanks for the quick reply! Here is what I ended up with.
tunnel.mysite.com {
                header_up Connection {http.request.header.Connection}
                header_up Upgrade {http.request.header.Upgrade}
Websockets should work with v2’s reverse proxy by default. @petebytes If you remove these lines:
Does it still work for you?
It does! Thanks :slight_smile:
Great!
To clarify, in v2, you do not need to do anything to enable websockets.
