I have a really great Caddyfile. I’m using a forward_auth directive to authenticate a request. The upstream gives me an other upstream to serve the request to which I reverse_proxy the original request. It looks like this:
auto_https off
http://localhost:2000 {
forward_auth localhost:8080 {
uri /init
copy_headers X-Upstream-Address
reverse_proxy {header.X-Upstream-Address}
This works like a charm. Truly impressed. Now I want to add some health check to this reverse_proxy upstream. Seems simple enough;
auto_https off
uri /init
reverse_proxy {header.X-Upstream-Address} {
health_uri /ping
This doesn’t work. When running Caddy it throws an error. It complains about an unrecognized placeholder. It doesn’t matter if I move the placeholder to a to directive inside the reverse_proxy.
Any ideas?
❯ caddy run
2023/04/07 19:44:28.780 INFO using adjacent Caddyfile
2023/04/07 19:44:28.782 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//[::1]:2019", "//127.0.0.1:2019", "//localhost:2019"]}
2023/04/07 19:44:28.782 WARN http automatic HTTPS is completely disabled for server {"server_name": "srv0"}
2023/04/07 19:44:28.782 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc000398f50"}
2023/04/07 19:44:28.782 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2023/04/07 19:44:28.782 ERROR http.handlers.reverse_proxy.health_checker.active invalid use of placeholders in dial address for active health checks {"address": "", "error": "unrecognized placeholder {http.request.header.X-Upstream-Address}"}
2023/04/07 19:44:28.782 INFO tls cleaning storage unit {"description": "FileStorage:/home/harm/.local/share/caddy"}
2023/04/07 19:44:28.782 INFO tls finished cleaning storage units
2023/04/07 19:44:28.782 INFO autosaved config (load with --resume flag) {"file": "/home/harm/.local/share/caddy/autosave.json"}
2023/04/07 19:44:28.782 INFO serving initial configuration
❯ caddy version
v2.6.4
Installed with pacman.
❯ uname -av
Linux mjolnir 5.19.17-2-MANJARO #1 SMP PREEMPT_DYNAMIC Sun Nov 6 00:08:27 UTC 2022 x86_64 GNU/Linux
n/a
see beginning of message
The original Caddyfile came to be after some excellent help: Programmatically update config from a Go program - #16 by haarts
