v2.1.1
DDNS for caddy.mydomain.com resolves to my ip. This fqdn is in my Caddyfile. I am able to see the Caddy splashpage, and it runs on HTTPS like it should. plex.mydomain.com is a CNAME to caddy.mydomain.com
ubuntu server 18.04 via apt repo
systemctl start caddy
systemctl stop caddy
systemctl reload caddy
# domain name.
caddy.mydomain.com
root * /usr/share/caddy
# php_fastcgi localhost:9000
plex.mydomain.com {
reverse_proxy http://10.0.80.247:32400
I receive an “unrecognized directive” error when attempted to do a reverse proxy. I’ve tried both reverse_proxy and proxy / methods - both give the same error. Even putting the subdomain entry in the caddy file with nothing in it gives me the error.
adapt: Caddyfile:25: unrecognized directive: plex.mydomain.com
Tried several ways to format the reverse proxy block.
