Unrecognized directive: rate_limit
After upgraded from 2.6.2 to 2.9.1 my Caddy file in no longer working around the 2 plugins:
rate_limit and maxmind_geolocation
for rate_limit:
Error: adapting config using caddyfile: /etc/caddy/Caddyfile:11: unrecognized directive: rate_limit
Error: adapting config using caddyfile: getting matcher module 'maxmind_geolocation': module not registered: http.matchers.maxmind_geolocation
Ubuntu 22.04.5 LTS
sudo apt update
sudo apt install caddy
xcaddy build --with github.com/porech/caddy-maxmind-geolocation
xcaddy build --with github.com/mholt/caddy-ratelimit
Before, I’m just update the system “sudo apt update” …
withe the same outcome
crios.bris.fr:777 {
# rate limit for all client (static_limit) and each client (dynamic_limit)
       rate_limit {
               distributed
               zone static_limit {
                       key static
                       events 100
                       window 10s
               zone dynamic_limit {
                       key {remote_host}
                       events 400
                       window 1m
reverse_proxy 192.168.9.201:5000
When customizing the build after installing Caddy using the apt repo, you’re supposed to follow the instructions here:
Thanks for the answer,
I did it and it’s working for the rate_limit but not for the maxmind_geolocation
Error: adapting config using caddyfile: getting matcher module ‘maxmind_geolocation’: module not registered: http.matchers.maxmind_geolocation
I’ve reverted to the previous version of the system and used caddy-upgrade
The caddyfile was working, but the system was
and after:
sudo apt update
sudo apt full-upgrade
and the error happened
So I’ve reinstalled caddy and the 2 plugins with no success
=> same error
Try this instead:
xcaddy build \
   --with github.com/porech/caddy-maxmind-geolocation \
If you run multiple xcaddy build commands, the latter one overrides the former one. You need to list all plugins within the same xcaddy build.
Thanks for your help.
It works well :pray:
