1. What version of Caddy are you using (caddy -version
Caddy (untracked dev build) (unofficial)
git checkout -b aftersan f6e50890b3d81cb04146bd7b2c2b59e99830849a
2. What are you trying to do?
Use TLS with IP addresses (not DNS) for local development. Everything has worked fine up to and including commit 22dfb140d0b3587dc9de4f2f15f93a9f319becf2 right before the TLS alert commit. I am not sure if this is a problem with (1) Caddy correctly handling invalid certificates or (2) Caddy incorrectly handling valid certificates. Nothing jumped out at me when examining the commit diffs so I will not be surprised if the fault is with the certificates. Any insights are appreciated.
3. What is your entire Caddyfile?
https://192.168.1.2 {
tls cert/pki/issued/192.168.1.2.bundle.crt cert/pki/private/192.168.1.2.key
More details on the certificates can be found below.
4. How did you run Caddy (give the full command and describe the execution environment)?
caddy -conf ./Caddyfile
5. Please paste any relevant HTTP request(s) here.
curl --cacert cert/pki/ca.crt https://192.168.1.2
6. What did you expect to see?
<h1>Hello from Caddy</h1>
This is what I get with versions of Caddy before the TLS alert commit.
7. What did you see instead (give full error messages and/or log)?
8. How can someone who is starting from scratch reproduce the bug as minimally as possible?
Here are the steps in the form of a shell script. Sorry for the involved sequence, but nothing is easy when it comes to TLS certificates.
# --- Obtain, install and initialize easyrsa ---
wget https://github.com/OpenVPN/easy-rsa/releases/download/v3.0.5/EasyRSA-nix-3.0.5.tgz
mkdir -p ~/tmp/caddy
tar -xzf EasyRSA-nix-3.0.5.tgz -C ~/tmp/caddy
mv ~/tmp/caddy/EasyRSA-3.0.5 ~/tmp/caddy/cert
cd ~/tmp/caddy/cert
cat > vars <<end-of-vars
set_var EASYRSA_PKI "$PWD/pki"
set_var EASYRSA_DN "cn_only"
set_var EASYRSA_KEY_SIZE 2048
set_var EASYRSA_ALGO rsa
set_var EASYRSA_CA_EXPIRE 3650
set_var EASYRSA_CERT_EXPIRE 3650
set_var EASYRSA_CRL_DAYS 180
set_var EASYRSA_NS_SUPPORT "no"
set_var EASYRSA_NS_COMMENT "Easy-RSA Generated Certificate"
set_var EASYRSA_TEMP_FILE "$EASYRSA_PKI/extensions.temp"
end-of-vars
./easyrsa init-pki
# --- Generate certificate authority, specify CA name interactively ---
./easyrsa build-ca nopass
# --- Generate self-signed server certificate with IP SAN ---
./easyrsa --subject-alt-name="IP:192.168.1.2" build-server-full 192.168.1.2 nopass
cat pki/issued/192.168.1.2.crt pki/ca.crt > pki/issued/192.168.1.2.bundle.crt
#--- Fire up caddy with minimal configuration
cd ..
cat > index.html <<end-of-index
end-of-index
cat > Caddyfile <<end-of-cfg
end-of-cfg
caddy -conf ./Caddyfile &
# --- Test with curl
# With caddy before TLS alert commit: <h1>Hello from Caddy</h1>
# With caddy after commit: curl: (35) error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error
